set gain ceiling
chrisPyres66
set gain ceiling
Postby chrisPyres66 » Tue Jun 04, 2019 8:08 am
Dear all,
I try to understand how works the gain in the OV7725 camera, and i stopped on the gain ceiling.
To set the gain ceiling there is 2 ways in python :
- sensor.set_gainceiling(4)
- sensor.set_auto_gain(True, gain_db_ceiling=4)
which both write at the COM9 register but the c language codes do it in 2 different ways.
Here is the test code :
import sensor
sensor.skip_frames(time = 500)
print("set_gainceiling : ", hex(sensor.__read_reg(0x14)))
sensor.set_auto_gain(True, gain_db_ceiling= 4)
print("set_auto_gain : ", hex(sensor.__read_reg(0x14)))
The result for 4db is ;
- set_gainceiling : 0x11 (this is right)
- set_auto_gain : 0x1 (this is not right)
Do i miss something ?
Re: set gain ceiling
Postby iabdalkader » Tue Jun 04, 2019 9:58 am
set_gainceiling takes multipliers not db. So 4 means 4x the value is the max gain.
chrisPyres66
Postby chrisPyres66 » Tue Jun 04, 2019 10:53 am
well, i see
- set_gainceiling : 2, 4, 8, 16 or 32 for x2, x4, x8, x16 or x32
- set_auto_gain : 2 to 32db
But i dont still understand teh relationship between gain and register ?
Postby iabdalkader » Tue Jun 04, 2019 10:58 am
I think it's explained some where in an appnote.
Postby kwagyeman » Tue Jun 04, 2019 12:21 pm
The ceiling is how much the auto algorithm goes up too.
Users browsing this forum: Baidu [Spider] and 6 guests
