Wireless TV Shield Interupts the UART(3) Receiving Data
Psilym
Postby Psilym » Thu May 30, 2019 2:35 am
Today, when I have tried the function of uart receiving data, I found that I can receive 00 01 ... 09 in sequence on openmv without using tv.display() function. However, the data gets bad when I use uart.read() followed by tv.dispaly() function. The problem has been solved if I separate this 2 function into different part of the while(True) .
But what behind this phenomenon is what I'm figuring out. Hope to solve the problem.
Psilym
Re: Wireless TV Shield Interupts the UART(3) Receiving Data
Postby Psilym » Thu May 30, 2019 3:40 am
Now I find the way of separating the two funcs can only alleviating problem, but can not fix it. Only get off the tv.display() can make the data receiving perfect.
Postby kwagyeman » Thu May 30, 2019 11:05 am
This is weird. Um, whats the data rate the data is received at? The tv.diplay() method uses SPI and disables interrupts for a while while sending data. Is the UART running very fast?
Here's the display method: https://github.com/openmv/openmv/blob/m ... _tv.c#L540
You aren't using pins it uses right?
Psilym
Postby Psilym » Fri May 31, 2019 1:06 am
Thank you very much! Your reply exactly explains the problem that we meet. The baud rate we use is 115200 which may be a little fast! Thanks again! :D
Postby kwagyeman » Fri May 31, 2019 1:46 am
Hmm, yeah, it probably takes longer than the serial buffer has time to buffer data for before needing to be serviced by the CPU.
