FLIR Thermal Camera Person Detection
Postby kwagyeman » Fri May 17, 2019 2:18 am
Ibrahim made this example script showing off person detection using the FLIR Thermal camera. Works with any FLIR Lepton.
import sensor, image, time, os, nn
sensor.set_pixformat(sensor.GRAYSCALE)    # Set pixel format to RGB565
sensor.set_framesize(sensor.QQVGA)      # Set frame size to QVGA (320x240)
sensor.set_windowing((32, 64))       # Set 128x128 window.
sensor.skip_frames(time=1000)
net = nn.load('/person.network')
    clock.tick()                    # Update the FPS clock.
    out = net.forward(img, softmax=True)
    if out.index(max(out)) == 0:
        print("person detected")
Save the person.network to your SD card.
person.zip
(64.08 KiB) Downloaded 392 times
Users browsing this forum: No registered users and 8 guests
