LBP
chrisPyres66
LBP
Postby chrisPyres66 » Mon May 06, 2019 10:49 am
Dear All,
I use lbp descriptor to recognize a pattern and, to filter local noise, i divide the image in several part with each a lbp descriptor.
My problem is if i use more than 4 lbp pattern, whatever the resolution, i have frequently deconnexion and it does not seem stable.
Do you have any knowledge about this problem and advice to do it better ?
Re: LBP
Postby iabdalkader » Mon May 06, 2019 1:55 pm
Code ?
chrisPyres66
Re: LBP
Postby chrisPyres66 » Tue May 07, 2019 8:27 am
Below is the simplified code, where you can define the number of line and column which define the number of areas where the lbp is defined and checked.
I tested the M7 and H7 camera, and both get problem if i increase the number of line and column.
With openmv 2.2.0 :
For M7 (rev 3.4.1), in VGA :
- 1 line and 1 column works
- 1 line and 2 column works
- 2 line and 1 column does not work
- 2 line and 2 column does not work
It stops at the lbp save step.
For H7 (rev 3.4.1), in VGA :
- 3 lines and 3 columns works but disconnect
import sensor, image
# Reset sensor
sensor.set_contrast(1)
sensor.set_gainceiling(16)
sensor.skip_frames(time=1000)
# Variable to define
nline = 4
ncolumn = 4
thres = 15000
stext = 2
# Size definition
zoneW = sensor.width()
zoneH = sensor.height()
wcolumn = int(zoneW / ncolumn)
hline = int(zoneH / nline)
# Save lbp features
mode = "save"  #0
if mode == "save" :
   print("save -------------")
   for i in range(0,nline) :
      for j in range(0,ncolumn) :
         dn = img.find_lbp( (int(j*wcolumn), int(i*hline), int(wcolumn), int(hline)) )
         n = i*ncolumn+j
         filename = "lbp" + str(n) + ".lbp"
         if image.save_descriptor(dn, "%s" % filename) == False :
            print("Error : ", filename)
print("check -------------")
while (True):
   OK = 0
   for i in range(0, nline) :
      for j in range(0, ncolumn) :
         d1 = img.find_lbp( ( int(j*wcolumn), int(i*hline), int(wcolumn), int(hline) ) )
         filename = "lbp%d.lbp" % int(i*ncolumn+j)
         dn = image.load_descriptor("%s" % filename)
         dist = image.match_descriptor(dn, d1)
         img.draw_string(int(j*wcolumn), int(i*hline) + 10, "%d" % dist, color=(0,0,0), scale=stext)
         if dist < thres :
            OK += 1
   if OK > 0 :
      print( "O_Ok : %d" % OK)
   else :
      print("Nok")
It seems to be a memory problem, but i dont know how free memory.
Thanks for help,
Re: LBP
Postby iabdalkader » Tue May 07, 2019 1:14 pm
It's a bug in LBP ROI. Can you test the attached image ?
firmware.zip
(923.11 KiB) Downloaded 196 times
chrisPyres66
Re: LBP
Postby chrisPyres66 » Thu May 09, 2019 9:01 am
Wowwwww, i tested a 6x6 lbp on M7, and it works fine.
Which file from github i have to update to get this ?
Re: LBP
Postby iabdalkader » Thu May 09, 2019 9:19 am
lbp.c
chrisPyres66
Re: LBP
Postby chrisPyres66 » Thu May 09, 2019 10:44 am
I red lbp.c and i discovered the weight are optimized for face recognition.
I would like to use for another use, what is the default values, and how can i define it to my own case ?
Re: LBP
Postby iabdalkader » Thu May 09, 2019 11:14 am
I think it depends on the application, you should search for LBP papers.
chrisPyres66
Re: LBP
Postby chrisPyres66 » Fri May 10, 2019 6:16 am
Well i understand than lbp_weights has a high value around eyes, medium value for mouth and ear, then low level for cheeks.
If i want to have a neutral use, i can set 1 for all the 7x7 matrix.
I dont understand what is for the uniform_tbl matrix ?
Re: LBP
Postby iabdalkader » Fri May 10, 2019 8:50 am
Please see the "Face Recognition with Local Binary Patterns" paper if you want more details.
chrisPyres66
Re: LBP
Postby chrisPyres66 » Mon May 13, 2019 5:04 am
well, the uniform matrix is to reduce the number of lbp (256 possibility) to 59 most common.
So it is not usefull to change for specific use.
Users browsing this forum: MSN [Bot], pcls1026 and 3 guests
