LCD Shield Issue
deroses
LCD Shield Issue
Postby deroses » Tue Apr 30, 2019 12:34 pm
Taking this thread from https://www.robotshop.com/community/for ... ng/43370/2
Summary - I think my shield is not working but wanted to confirm before returning. Details in the link above, but in case that link ever dies:
1. Plugged in shield to working openmv board - attempted the hello world of the lcd shield and it fails at init().
2. Setting type=0 passes the init() probably because it skips it: setting type=1 fails at that line.
Any other thoughts or options? Thank you!
Re: LCD Shield Issue
Postby kwagyeman » Tue Apr 30, 2019 7:10 pm
Hi, the lcd shield usually works. If it failed the default lcd example script when connected correctly then it's broken. That said, you plugged it in such that the backlight on the screen turned on and that all I/O pins were connected right?
deroses
Postby deroses » Tue May 14, 2019 10:17 am
Nope - I had the same issue as this person: viewtopic.php?f=6&t=1309&p=8106&hilit=lcd+shield#p8106
I'll re-solder the correct way and, if that doesn't work, let you know.
Postby iabdalkader » Tue May 14, 2019 10:55 am
We didn't realize that this is a common issue. Maybe we should write that on the silkscreen on the back of the LCD shield.
Users browsing this forum: No registered users and 8 guests
