Has anyone experienced image washout on the M7 when going from shadow to light, and vice versa, such as in the attached photos? If so, how did you solve it? A polarizing filter is already installed and the issue is inconsistent.
I think that’s just the AGC and AEC working, they need time to settle down when going from a very bright to a very dark image or the other way around.
Hi, just turn AGC and AWB off immediately. If you see my color tracking scripts I wait 2000 ms. Lower the wait to like 100 ms.
Oooh. Thank you!
AGC: What is the code for this?
AWB: sensor.skip_frames(time = 2000 → 100)
Just in case the code is attached.
MVPRacer_Calibration_Red_Rev03_WorksWell.py (7.03 KB)
AWB - automatic white balance
AGC - Automatic gain control
See the color tracking scripts and you’ll see these terms used.
Will do.
Thank you!
