What does it mean ?
duyci
What does it mean ?
Postby duyci » Wed Mar 13, 2019 4:17 pm
This is the example code of the QR code. But I have some question about the this code.
What is the code mean in this line
 for code in img.find_qrcodes():
And what is the behind of the find_qrcodes() function. How can I find the explanation about the some function.
# QRCode Example
# This example shows the power of the OpenMV Cam to detect QR Codes
# using lens correction (see the qrcodes_with_lens_corr.py script for higher performance).
import sensor, image, time
sensor.set_auto_gain(False) # must turn this off to prevent image washout...
    img.lens_corr(1.8) # strength of 1.8 is good for the 2.8mm lens.
        img.draw_rectangle(code.rect(), color = (255, 0, 0))
        print(code)
Re: What does it mean ?
Postby kwagyeman » Thu Mar 14, 2019 11:55 am
Hi, the method finds QR Codes. The C code that implements it is here:
https://github.com/openmv/openmv/blob/m ... g/qrcode.c
