facing problem in wifi streaming after disconnecting from ide
elight-spm
Postby elight-spm » Fri Jan 11, 2019 3:09 pm
hello sir,i am running a neural network code with wifi streaming. But as we disconnect the openmv from the ide,It stops streaming video..when it is connected with the ide,Then it works properly in both frame buffer and over wifi.But as we disconnect openmv from ide,it stops streaming.i am attaching my code,Please check . i am eagerly waiting for your help.
cifar10_fast_espm2.py
(3.07 KiB) Downloaded 238 times
Re: facing problem in wifi streaming after disconnecting from ide
Postby iabdalkader » Fri Jan 11, 2019 5:37 pm
You need to save the script as main.py
MANASH
Postby MANASH » Sat Jan 12, 2019 12:00 am
Okay sir. Thank you so much.
Users browsing this forum: Google [Bot] and 5 guests
