Are the ML examples written for the H7 (heap errors on M7)
kwiley
Postby kwiley » Fri Jan 11, 2019 2:40 pm
I can run the CIFAR10_fast example, which uses a smaller network file, but I can't run the other CIFAR example or the Levet example or the Smile example. They produce heap errors immediately. They also seem to depend on an SD card in that the on-board flash isn't big enough to transfer the network descriptions over to the board. But even with an external SD card, they still generate heap errors when they run. Were most of these examples written against the H7 as opposed to the M7?
Thanks.
Re: Are the ML examples written for the H7 (heap errors on M7)
Postby iabdalkader » Fri Jan 11, 2019 5:46 pm
Yes most of the networks need more RAM, only the cifar10_fast works on the F7.
Users browsing this forum: No registered users and 10 guests
