image drawstring() landscape orientation (or image rotation function)?
kwiley
Postby kwiley » Fri Jan 11, 2019 12:56 pm
Is there a straightforward way to write text onto the image in landscape orientation? I see no parameters to Image.draw_string() that would do this out of the box.
Alternatively, is there correspondingly simple way to rotate an image (one could rotate, write text, then rotate back in order to maintain an upright display). Neither the sensor nor the image modules seem to offer rotation functions.
Thanks.
Re: image drawstring() landscape orientation (or image rotation function)?
Postby iabdalkader » Fri Jan 11, 2019 6:02 pm
Thanks.
No not that I know of, the text was originally added for displaying the FPS. If you like you could submit a feature request on github for text rotation (much easier, faster to implement than the alternative)
Postby kwagyeman » Sat Jan 12, 2019 12:49 pm
Hi, the latest firmware build offers vertical and horizontal mirroring along with image rotation. This does exactly what you want.
# Vertical Flip - Horizontal Mirror - Transpose
# This example shows off how to vertically flip, horizontally mirror, or
# transpose an image. Note that:
# vflip=False, hmirror=False, transpose=False -> 0 degree rotation
# vflip=True,  hmirror=False, transpose=True  -> 90 degree rotation
# vflip=True,  hmirror=True,  transpose=False -> 180 degree rotation
# vflip=False, hmirror=True,  transpose=True  -> 270 degree rotation
mills = pyb.millis()
counter = 0
    img = sensor.snapshot().replace(vflip=(counter//2)%2,
                                    hmirror=(counter//4)%2,
                                    transpose=(counter//8)%2)
    if (pyb.millis() > (mills + 1000)):
        counter += 1
firmware.zip
(920.08 KiB) Downloaded 40 times
kwiley
Postby kwiley » Sat Jan 12, 2019 8:04 pm
Thanks. It isn't a crucial feature. It's just nice to support more a traditional landscape orientation is all. I'll give it a shot.
Users browsing this forum: Bing [Bot] and 4 guests
