QUESTION ABOUT I2C CONNECTION
Raul_
Postby Raul_ » Fri Jan 11, 2019 8:41 am
HI, engineers from OPENMV!
I am a newcomer and I just met some problems when connecting my openmv to a mlx90614 temperature sensor. i guess it is the connection problem since I have try to `i2c.scan()` and no valid address returned.
this is my code and how i connect the wires.
# This example is to get the ambient temperature and object temperature by the I2C bus
# Hardware : MLX90614, OpenMV
# connect I2C
#   MLX90614  OpenMV
#   VCC       VCC
#   GND       GND
#   SCL       SCL
#   SDA       SDA
from pyb import I2C
_MLX90614_IIC_ADDR   = (0x5A)
_MLX90614_TA         = (0x06)
_MLX90614_TOBJ1      = (0x07)
class MLX90614:
  def __init__(self,i2c,addr=_MLX90614_IIC_ADDR):
    self.addr=addr
    self.i2c=i2c
  def getObjCelsius(self):
    return self.getTemp(_MLX90614_TOBJ1)	#Get celsius temperature of the object
  def getEnvCelsius(self):
    return self.getTemp(_MLX90614_TA)    #Get celsius temperature of the ambient
  def getObjFahrenheit(self):
    return (self.getTemp(_MLX90614_TOBJ1) * 9 / 5) + 32  #Get fahrenheit temperature of the object
  def getEnvFahrenheit(self):
    return (self.getTemp(_MLX90614_TA) * 9 / 5) + 32 #Get fahrenheit temperature of the ambient
  def getTemp(self,reg):
    temp = self.getReg(reg)*0.02-273.15             #Temperature conversion
    return temp
  def getReg(self,reg):
    data = self.i2c.mem_read(3,self.addr,reg)               #Receive DATA
    result = (data[1]<<8) | data[0]
    return result
i2c=I2C(2,I2C.MASTER,baudrate=100000)
print(i2c.is_ready(_MLX90614_IIC_ADDR))
ir=MLX90614(i2c)
  time.sleep(2000)
  print("Object  %s *C"% ir.getObjCelsius())        #print celsius of Object
  print("Object  %s *F"% ir.getObjFahrenheit())     #print fahrenheit of Object
  print("Ambient %s *C"% ir.getEnvCelsius())        #print celsius of Ambient
  print("Ambient %s *F"% ir.getEnvFahrenheit())     #print fahrenheit of Ambient
  print()
Re: QUESTION ABOUT I2C CONNECTION
Postby kwagyeman » Fri Jan 11, 2019 12:09 pm
Hi, you need pull up resistors on the I2C lines. The OpenMV Cam doesn't pull the lines up by default. I2C Scan should work once you do that.
Raul_
Postby Raul_ » Fri Jan 11, 2019 8:54 pm
Thank you very much for your reply. I check my sensor and it is integrated with pull up resistors.
QAQ
Postby iabdalkader » Fri Jan 11, 2019 9:31 pm
I think you're connecting VIN to VIN, that's the power input pin on the OpenMV cam. You should connect the sensor's VIN to 3.3/vout.
Raul_
Postby Raul_ » Fri Jan 18, 2019 4:33 am
Thank you very much!!!! It really fixes my problem!! OpenMV is really a easy-to-use product!
