External antenna on WIFI Shield?
fsikkerm
Postby fsikkerm » Sat Dec 22, 2018 3:11 am
Hi all,
My solution needs to be enclosed in an RVS metal casing.
I fear the WIFI signal will be lost, since the shield has no external antenna connector..
Can you alter the wifi shield to connect it an external antenna ?
Something like this (attached) ?
Re: External antenna on WIFI Shield?
Postby iabdalkader » Sat Dec 22, 2018 6:39 pm
Hi all,
Hi, there's another WINC1500 that comes with a uFL connector instead of the trace antenna, if you're up to desoldering and replacing the module.
