How to only send self-allocated framebuffer to OpenMV IDE?
iamseer
Postby iamseer » Sun Dec 16, 2018 10:08 am
I met the same problem to this: https://stackoverflow.com/questions/527 ... openmv-ide
I want to show my own image for debugging purpose. However, it seems OpenMV sends my framebuffer and camera framebuffer alternatively. Currently, I have to use an LCD to show the framebuffer I want, but the LCD is slow and inconvenient.
Is there a way to disable OpenMV sending camera framebuffer? I've attached a sample code which flashes framebuffer viewer in IDE
invImg = sensor.alloc_extra_fb(sensor.width(), sensor.height(), sensor.RGB565)
    invImg.replace(img)
    invImg.invert()
    print(invImg.compressed_for_ide(), end="")
Re: How to only send self-allocated framebuffer to OpenMV IDE?
Postby iabdalkader » Tue Dec 18, 2018 8:41 am
Hi, if you don't need the snapshot you could just overwrite it :
    img.invert()
If you still need it, you could copy the inv image back to img:
    invImg.replace(img)
    invImg.invert()
    img.replace(invImg)
