problem when i receive data on Uart rx when i read
chrisPyres66
Postby chrisPyres66 » Wed Dec 12, 2018 6:50 am
I have got a problem when i receive data on Uart rx when i read.
Here is my test code :
import pyb,time
red_led = pyb.LED(1)
red_led.off()
uart=pyb.UART(3,14400)
uart.init(14400, bits=8, parity=None, stop=1) #, timeout_char=20
   time.sleep(500)
   if uart.any():
      uchar=uart.read(1)
      print('==> Info -------------')
      print(uchar)
      red_led.toggle()
I send "0x0F 0x00 0x0F 0x00 0x0F 0x00 0x0F 0x00" number with realterm software every half second (quick click) and the camera stops.
i dont have the same behavior if i send 50x this number at once because the uart buffer is limited.
It looks like the uart buffer index is lost when the reading is during the reception.
Do i do something wrong ?
Re: problem when i receive data on Uart rx when i read
Postby kwagyeman » Wed Dec 12, 2018 12:42 pm
I don't quite understand what you care trying to do. How many characters are you sending between the 0.5s waits?
chrisPyres66
Postby chrisPyres66 » Thu Dec 13, 2018 2:55 am
Well, i discovered the problem when i tried to send image over UART to a master which does something else, lose a part of the data and try to restart a new synchronization.
To reproduce the behavior, I send several datas by frame (like 0x0F 0x00 0x0F 0x00 0x0F 0x00 0x0F 0x00) every ~0.5s when the camera is reading the buffer slowly (one data every 0.5s).
This does not happen when i send at once a very big frame (like 50 times 0x0F 0x00 0x0F 0x00 0x0F 0x00 0x0F 0x00) because the uart buffer is a circular list i assume.
I hope it is clearer.
Postby kwagyeman » Thu Dec 13, 2018 12:28 pm
Ibrahim, can you help out?
Postby iabdalkader » Thu Dec 13, 2018 4:31 pm
Hi, no I don't understand the problem either. Can you post steps + code to reproduce ?
chrisPyres66
Postby chrisPyres66 » Fri Dec 14, 2018 3:08 am
Lol, ok i try again !
Here is a new test code with image snapshot :
import pyb,time, sensor
   time.sleep(500)
   if uart.any():
      uchar=uart.read(1)
      print(uchar)
I join a picture, where you can see Openmv IDE and Realterm software with the frame "0x00 0xFF 0x00 0xFF 0x00 0xFF 0x00 0xFF" and the "send Numbers" button.
After few quick clicks (10 times every half sec), the camera stops, disconnects and cant be reconnected (unplug and plug again the USB cable is necessary to reconnect the camera).
I hope it helps.
Postby iabdalkader » Sun Dec 16, 2018 11:53 am
I think this is the same issue:
https://github.com/micropython/micropython/issues/3375
Please try the attached firmware and let me know if it works.
firmware.zip
(898.52 KiB) Downloaded 31 times
chrisPyres66
Postby chrisPyres66 » Mon Dec 17, 2018 5:14 am
Tx it works with my code test, do you github it ?
I could test this and jpg exception.
Postby iabdalkader » Mon Dec 17, 2018 7:31 am
I was waiting for you to test it. I'll commit it now.
chrisPyres66
Postby chrisPyres66 » Tue Dec 18, 2018 4:29 am
Opposite to your firmware, the last git have the same previous behavior.
Postby iabdalkader » Tue Dec 18, 2018 8:15 am
This was committed to our micropython fork. I think you need to do a git pull in src/micropython too
Postby kwagyeman » Tue Dec 18, 2018 10:50 am
Do:
"git remote -v"
To see what repo you cloned off of. Then "git pull --rebase origin master" where origin should point to our github and master is the master branch.
chrisPyres66
Postby chrisPyres66 » Wed Dec 19, 2018 3:47 am
I am lost in github but the modification works for UART !
Here are the results to get the last modifications :
- git pull
in in src/micropython gives
Your are not in a branch...
- git remote -v
in openmv/ gives :
origin https://github.cm/openmv/openmv.git (fetch)
origin https://github.cm/openmv/openmv.git (push)
- git pull --rebase https://github.com/openmv/src/micropython.git master
in opemnv/ replaced all the openmv directory by micropython directory : OOups !
in openmv/src/python would have been better
- git clone --recursive https://github.com/openmv/openmv.git
gave the last modification
Users browsing this forum: No registered users and 8 guests
