Use of callback function in sleep mode
chrisPyres66
Postby chrisPyres66 » Thu Nov 22, 2018 10:28 am
Dear all,
I try to use a callback function when the camera wakeup from a sleep with this code :
import pyb, machine, time
red_led   = pyb.LED(1)
red_led.off()
def test(line) :
   red_led.toggle()
   return
rtc = pyb.RTC()
rtc.datetime((2014, 5, 1, 4, 13, 0, 0, 0))
rtc.wakeup(500, test(1) )
   machine.sleep()
   #test(0)
   #time.sleep(500)
When i run the programm, the led is just lighting once but never toggle after.
Thanks for your help
Re: Use of callback function in sleep mode
Postby kwagyeman » Thu Nov 22, 2018 1:25 pm
Ibrahim needs to check this.
Postby iabdalkader » Thu Nov 22, 2018 3:38 pm
Hi, there's a bug in our RTC interrupt handler, the fix will be in the next release (unless you want to build from source). Also note your code has a few issues, it won't work either way. This works fine:
red_led.off()
def test(arg):
    red_led.toggle()
rtc = pyb.RTC()
while (True):
    rtc.wakeup(1000, test)
    machine.sleep()
chrisPyres66
Postby chrisPyres66 » Fri Nov 23, 2018 2:48 am
Ok i try to get rtc and rebuild !
Or wait for new release if i dont success !
chrisPyres66
Postby chrisPyres66 » Fri Nov 30, 2018 6:15 am
I cloned the last git i think with
git clone --recursive https://github.com/openmv/openmv.git
compiled and program the firmware but the code below does not work
red_led.off()
def test(arg):
    red_led.toggle()
    return
rtc = pyb.RTC()
while (True):
    machine.sleep()
Do i something wrong ?
Postby iabdalkader » Fri Nov 30, 2018 10:50 am
No, it should work. Try git pull, and make clean and build again. Make sure you upload the firmware you build. It should be version 3.3.0
chrisPyres66
Postby chrisPyres66 » Tue Dec 04, 2018 9:15 am
Ok, you are right i should do :
git checkout .
git pull
i confirm callback funtion in sleep and deepsleep mode
