use of time.avg() in a function
chrisPyres66
Postby chrisPyres66 » Thu Nov 22, 2018 10:08 am
Dear all,
I try to get the time between two interrupts from a push on a button with the code :
import time, pyb
testClock = time.clock()
def test(line) :
   print( testClock.avg() )
   testClock.tick()
   return
testClock.tick()
pyb.ExtInt('P7', pyb.ExtInt.IRQ_FALLING, pyb.Pin.PULL_UP, test)
   time.sleep(10)
In openmvIDE, i have the error :
Uncaught exception in ExtInt interrupt handler line 12
MemoryError:
Any help could be pleased, Thanks,
Re: use of time.avg() in a function
Postby iabdalkader » Fri Nov 23, 2018 3:34 pm
You can't call any functions that allocate memory in an interrupt handler. Try something like this:
import time, pyb
def test(arg):
    global ticks_passed, last_tick, extint, switch
    switch = True
    extint.disable()
    ticks_passed = time.ticks() - last_tick
    last_tick = time.ticks()
switch = False
ticks_passed = 0
extint = pyb.ExtInt('P7', pyb.ExtInt.IRQ_FALLING, pyb.Pin.PULL_UP, test)
    if (switch):
        switch = False
        print(ticks_passed)
        extint.enable()
Users browsing this forum: Bing [Bot], Google [Bot] and 137 guests
