Use OpenMV with D1 Mini shields
deshipu
Contact:
Postby deshipu » Tue Nov 13, 2018 11:26 am
I just wanted to drop a quick note that I made this very simple PCB adapter for using shields for the D1 Mini boards with the OpenMV boards:
It's really simple, just remapping the pins and adapting to the different size of the shield. I left the TX and RX pins unconnected, because OpenMV doesn't have that many pins, and I don't know of any shields that would use those (normally you need them for programming and USB serial on the D1 Mini). I also used staggered holes, so if you use male pin headers, you don't even need to solder — you can plug the headers straight into the holes, and they will hold them. I hope that this will prove useful to someone.
OSHPark link: https://oshpark.com/shared_projects/MqDuZraj
Gerbers:
gerber.zip
(90.54 KiB) Downloaded 31 times
Re: Use OpenMV with D1 Mini shields
Postby kwagyeman » Tue Nov 13, 2018 12:00 pm
Send a PR to the boards repo: https://github.com/openmv/openmv-boards
deshipu
Contact:
Postby deshipu » Tue Nov 13, 2018 1:16 pm
Good idea, done.
