edge detection
hamidnawaz28
edge detection
Postby hamidnawaz28 » Sat Oct 27, 2018 6:56 am
Hi there, I'm implementing a function for canny edge detection(don't want to implement through library) but getting a lot of trouble plz guide me how i can make it work.
Basically i'm converting this code from matlab function mentioned below:
Open MV CODE:
import sensor, image,time,math
img=sensor.snapshot()
numrow=sensor.width()
numcol=sensor.height()
def edgedetect(img,edgeNum,a):
    for i in range[1:32]:
        for j in range[1:33]:
            imagi[i,j]=255
    for col in range(1,numcol):
        sv = (img(1,col) + img(2,col) + img(3,col)) / 3
        ev=(img(30,col) + img(31,col) + img(32,col)) / 3
        threshold= (0.3*(ev-sv)) + sv
        temp[a]=threshold
        a=a+1
    for row in range(2,29):
            if (img(row,col)>threshold) & (img(row + 1,col)>threshold) & (img(row+2,col)>threshold) & (img(row+3,col)>threshold):
                if (img(row - 1,col)) > (0.1* img(row,col)):
                    edgeNum = edgeNum + 1
                    edgecoor[edgeNum,1] = col
                    edgecoor[edgeNum,2] = row - 1
                    imagi[row-1,col]=0
                        imagi[row,col]=0
            break
    return edgecoor,imagi,edgeNum
edgecoor,imagi,edgeNum=edgedetect(img,edgeNum=0,a=1)
Mathlab code: Accurately working
function [edgecoor,image,edgeNum]=edgedetect(imagebuffer,edgeNum,a)
subplot(311)
imshow(imagebuffer)
imagebuffer=rgb2gray(imagebuffer);
subplot(312)
imshow(imagebuffer)
    imagebuffer=imresize(imagebuffer, [32 31]);
    %displayig original image
    subplot(313)
    imshow(imagebuffer)
    [numrow,numcol]=size((imagebuffer));
    for i=1:31
        for j=1:32
            image(i,j)=255;
        end
    end
    for col=1:numcol        %Finding an edge in each column from top to bottom
        sv = (imagebuffer(1,col) + imagebuffer(2,col) + imagebuffer(3,col)) / 3;                                             %detemining space value by taking average of top three pixels
        ev=(imagebuffer(30,col) + imagebuffer(31,col) + imagebuffer(32,col)) / 3;                                            %detemining earth value by taking average of bottom three pixels
        threshold= (0.3*(ev-sv)) + sv;
        %Threshold value i.e.avg sv + (30%(e.v-s.v))
        temp(a)=threshold;
        a=a+1;
    for row =2: 29
            if (imagebuffer(row,col)>threshold) && (imagebuffer(row + 1,col)>threshold) && (imagebuffer(row+2,col)>threshold) && (imagebuffer(row+3,col)>threshold)         %verify that the current pixel and three below are higher than threshold
                if (imagebuffer(row - 1,col)) > (0.1* imagebuffer(row,col))                                               %if col, then we check if the value is 10% of the pixel value
                    edgeNum = edgeNum + 1;
                    edgecoor(edgeNum,1) = col   ;        %if higher, then pixel is mapped as edge pixel of that rowumn
                    edgecoor(edgeNum,2) = row - 1;
                    image(row-1,col)=0;
                    else
                        edgecoor(edgeNum,1) = col;
                        edgecoor(edgeNum,2) = row;
                           image(row,col)=0;
                end
                     break;
                    end
    end
    end
Re: edge detection
Postby kwagyeman » Sat Oct 27, 2018 8:01 pm
Please post your code in the
 tags. See the button in the forum post editor.
hamidnawaz28
Re: edge detection
Postby hamidnawaz28 » Sun Oct 28, 2018 1:09 am
imagi[i,j]=255
temp[a]=threshold
a=a+1
imagi[row-1,col]=0
imagi[row,col]=0
break
Re: edge detection
Postby iabdalkader » Sun Oct 28, 2018 12:12 pm
Here I fixed some of your "code". Some variables are not defined, I just removed them. I don't think it's working as expected, and I don't think you'll have enough memory to implement this, but anyway:
def edgedetect(img, edgeNum, a):
    for i in range(1, 32):
        for j in range(1, 33):
            img.set_pixel(i, j, 255)
    for col in range(1, numcol):
        sv = (img.get_pixel(1, col) + img.get_pixel(2, col) + img.get_pixel(3, col)) / 3
        ev = (img.get_pixel(30, col) + img.get_pixel(31, col) + img.get_pixel(32, col)) / 3
        threshold = (0.3*(ev-sv)) + sv
        a=a+1
        if (img.get_pixel(row, col)>threshold) and (img.get_pixel(row + 1,col)>threshold) and (img.get_pixel(row+2,col)>threshold) and (img.get_pixel(row+3,col)>threshold):
            if (img.get_pixel(row - 1, col)) > (0.1* img.get_pixel(row, col)):
                img.set_pixel(row-1, col, 0)
                img.set_pixel(row, col, 0)
            break
    return img, edgeNum
img, edgeNum = edgedetect(img, edgeNum=0, a=1)
Re: edge detection
Postby kwagyeman » Sun Oct 28, 2018 11:50 pm
Hi, do you have the ability to edit the C code? If you have a linux PC then you can. It doesn't take that long to pull our firmware and compile it. In C you can do whatever algorithm you want.
hamidnawaz28
Re: edge detection
Postby hamidnawaz28 » Mon Oct 29, 2018 11:34 am
how we can resize our image like
img=imresize(img, [32 31]);
hamidnawaz28
Re: edge detection
Postby hamidnawaz28 » Mon Oct 29, 2018 11:36 am
how we can resize our images like
Re: edge detection
Postby kwagyeman » Mon Oct 29, 2018 11:56 am
Use the pool() methods. They don't give you an exact size however, they just down sample.
Note that our image resizing functionality is limited because we made a decision not to put this in back when we were on the M4. It's something I know needs to be added back. However, our current man power levels keeps it from getting worked on.
hamidnawaz28
Re: edge detection
Postby hamidnawaz28 » Sat Nov 03, 2018 9:12 am
plz help me to get edges of the sensor image
import sensor
sensor.set_framesize(sensor.B64X64)
        ev = (img.get_pixel(29, col) + img.get_pixel(30, col) + img.get_pixel(31, col)) / 3
        a=threshold
        a=a+1
            break
    return img, edgeNum
img=img.mean_pool(2,2)
numrow=img.width()
numcol=img.height()
Re: edge detection
Postby kwagyeman » Sat Nov 03, 2018 1:43 pm
Hi, please see the filtering examples -> mean filter with adaptive thresholding.
hamidnawaz28
Re: edge detection
Postby hamidnawaz28 » Sun Nov 04, 2018 8:38 am
in my case that filter is not helpful so help me to improve this code so that i can do any further coding using the results.
i have attached the desired results.
Re: edge detection
Postby kwagyeman » Sun Nov 04, 2018 12:42 pm
Hi, did you try to adjust the filter offset value and kernel size? No algorithm is going to produce the image on the right perfectly. You have to turn different knobs and apply filtering operations until you get the right result.
I don't really have time to write code anymore for users. I can just point you in the right direction.
Please try out the mean filter with adaptive thresholding again and try to adjust the kernel size and the offset value until you start getting a line of the edge. Once you get that we just need to do noise filtering to remove things we don't want.
hamidnawaz28
Re: edge detection
Postby hamidnawaz28 » Tue Nov 13, 2018 2:27 pm
why after running this code my frame-buffer screen stuck. And help me to implement this attached algorithm.
import sensor
    for i in range(0, 32):
        for j in range(0, 32):
    for col in range(0,32):
        threshold = 10
    for row in range(1,32):
                img.set_pixel(row-1, col,0),
            break
    save()
    return img, edgeNum
img=img.mean_pool(20,15)
row=img.width()
col=img.height()
print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
Re: edge detection
Postby kwagyeman » Wed Nov 14, 2018 12:13 am
Hi, the code gets stuck here:
Because you've broken the while loop.
Users browsing this forum: No registered users and 268 guests
