fastest way to get yuv table in firmware developing
kidswong999
Postby kidswong999 » Mon Oct 22, 2018 1:37 am
Hi, I am developing ntsc/pal shield. And writing driver in C.
viewtopic.php?f=6&t=948
I have done everything, except to send yuv table.
the vs23 chip need VUY 224 streaming,(other format 8bit is OK by setting the chip).
I don't know how to get YUV is the most convenient and most efficient.
Re: fastest way to get yuv table in firmware developing
Postby kwagyeman » Mon Oct 22, 2018 2:04 am
https://github.com/openmv/openmv/blob/m ... rgb2yuv.py ?
https://github.com/openmv/openmv/blob/m ... /yuv_tab.c ?
Um, the best way to send data to the chip is to fb _alloc a large array of bytes for the image size (3 bytes per pixel) and then send that buffer using SPI to the chip. See the py_lcd.c file (under src/omv/py) to see what to do. It's pretty straight forward. The LUT is already on chip with our firmware so just use (for RGB565 image only):
COLOR_RGB565_TO_Y(pixel)
COLOR_RGB565_TO_U(pixel)
COLOR_RGB565_TO_V(pixel)
And you'd put the values in the order they need to be in the buffer and then call the SPI write method to send them in one blast.
kidswong999
Postby kidswong999 » Mon Oct 22, 2018 3:10 am
my code:
uint8_t pixel = IM_GET_GS_PIXEL(arg_img, x, y);
uint8_t y = COLOR_RGB565_TO_Y(pixel);
uint8_t u = COLOR_RGB565_TO_U(pixel);
uint8_t v = COLOR_RGB565_TO_V(pixel);
uint8_t v2 = (v>>0)&0b11000000;        //this maybe wrong
uint8_t u2 = (u>>2)&0b00110000;
uint8_t y4 = (y>>4)&0b00001111;
uint8_t color = y4+u2+v2;
SpiSendReceiveByte(color);
COLOR_RGB565_TO_Y function is a macro.
Maybe the process of packaging yuv into a byte is wrong. :shock:
kidswong999
Postby kidswong999 » Mon Oct 22, 2018 7:16 am
I solved it.
TV can already display the image, then I will adjust the color, and optimize the efficiency :D
Thanks.
            uint16_t pixel = IM_GET_RGB565_PIXEL(arg_img, x, y);
            //uint8_t pixel = IM_GET_GS_PIXEL(arg_img, x, y);
            int8_t y8 = COLOR_RGB565_TO_Y(pixel);
            int8_t u8 = COLOR_RGB565_TO_U(pixel);
            int8_t v8 = COLOR_RGB565_TO_V(pixel);
            uint8_t y4 = (y8+128)>>4;
            uint8_t v2 = v8>>6;
            uint8_t u2 = u8>>6;
            int8_t color = y4+(u2<<6)+(v2<<4);
Postby kwagyeman » Mon Oct 22, 2018 12:08 pm
Post a video.
kidswong999
Postby kidswong999 » Tue Oct 23, 2018 5:30 am
I used a 16bit color and it was slower. The color is wrong and the red color will be displayed in green.
IMG_3704.mov
(5.31 MiB) Downloaded 46 times
Postby kwagyeman » Tue Oct 23, 2018 12:01 pm
Mmm, the SPI freq seems to slow?
Users browsing this forum: No registered users and 307 guests
