Send images to a webserver with OpenMV M7 + NodeMCU
vfernandezkim77
Postby vfernandezkim77 » Tue Apr 24, 2018 9:19 pm
This is literally my first forum post of any kind so let me know if I need to elaborate on anything.
As the title suggests I'm trying to send a snapshot image from the OpenMV cam to a webserver. This is to happen without the OpenMV Wifi Board (because they're not in stock right now) and I own a NodeMCU. Frankly, I'm new to both devices and very weak at coding so I'm looking for some guidance.
Doing a little researching, I think I will do the following:
1) SPI protocol between M7 cam and NodeMCU
2) NodeMCU as master(?). This was decided solely on the fact that there exists example code for Arduino(M)-M7 cam(S) SPI comms. Though, from what I've seen, it's more difficult this waY...?
3) No AT command firmware, Arduino API for NodeMCU
Is this a good approach? So far I have been trying to simply send a message ("Hello World") through SPI, with no luck. So I'm starting to doubt this method.
Thank you,
Victor
Re: Send images to a webserver with OpenMV M7 + NodeMCU
Postby kwagyeman » Wed Apr 25, 2018 1:59 am
Just send the image over UART. Just set the baud rate really high. The UART on the camera can go into the 1 Mb/s above range.
Here's how simple it is to send an image:
uart.send(img.snapshot().compress(quality=90))
That's just the sending part, you have to init the uart object and setup the camera. But, it's easy in general.
Afgty
Postby Afgty » Wed Jun 20, 2018 3:59 pm
Thank you,
Victor
have you finished it?
