I would like to use an OpenMV M7 to measure the gap between two paper bands while they run between two rolls on a production machine (I am attaching a picture took inside the machine).
Francesco
Referring to the picture, I image that a camera each gap between two strips will be required.
Since I am a newbie in computer vision I would really appreciate any kind of suggestions about the right techniques and and the more convenient software example to be followed.
Hi, for this application you’ll need a lot of horizontal res but not vertical res. So, set the resolution to VGA. Set the pix format to grayscale. Then set windowing to (640, 80).
Next, use lens_corr() to undo lens distortion. Also, you should use the wide angle lens with your application.
After this… If you mounted the OpenMV Cam right… You should be able to see two slits and then the start of the next piece of paper.
If so, then to get_historgram() on the image followed by get_threshold() on what get histogram returns. This will give you the best color thresholds to segment the image with.
Finally, do find_blobs() using those color thresholds and measure the maximum length of he biggest blob. This will tell you the paper width in pixels.
by re-reading your message I just realized that we had a misunderstanding: actually I need to measure the gap of a slit between two piece of paper.
I think the concept should be the same but, maybe, a littele more difficult to chose the right blob (I cannot pick the widther one…).
Hi, this code basically does what you want. Feel free to clean it up:
# Hello World Example
sensor.set_framesize(sensor.VGA) # Set frame size to QVGA (320x240)
sensor.set_windowing((640, 80))
sensor.skip_frames(time = 2000) # Wait for settings take effect.
threshold = img.get_histogram().get_threshold()
blobs = img.find_blobs([(0, threshold.value())], invert=False)
if blobs:
largest = max(blobs, key = lambda x: x.w())
img.draw_rectangle(largest.rect())
print(largest.w())
Hello I made some steps ahead on the project.
I decided to cover the machine width with several CAMs and I cannot predict if the the narrow gap between paper slits will be in front of a camera (maybe some of them will see only a white paper sheet).
I experienced that in this case the CAM is detecting some strange blobs in the image which have no sense for my application.
How could I filter the blobs “quality” in order to make sure that I will only obtain a gap measurement (in case no gap is visible by a CAM I should have no output)?
Ok. I’ll send it tomorrow.
For the time being you can image that in white paper the cam is detecting a threshold due to some shadows and it result in a blob detection.
The core of the program I am using is practically the one you suggested a few posts above this.
Ah, okay, so, the issue is because you need to adaptive threshold the image. You can use the mean/median/mode/midpoint methods to adaptively threshold the image. This will take care of shadows. You will then just get a black and white image where hard lines are. See the adaptive threshold example under filters.
