How to implement POST and GET
Ablon
Postby Ablon » Tue Feb 27, 2018 10:13 pm
Dear All,
I would like to request for a sample code/s based from original sample codes. While printing the data extracted to the Serial Monitor, it should also send the data via WIFI shield to a local Web Server, thank a lot for all the help.
# QRCode Example
# This example shows the power of the OpenMV Cam to detect QR Codes
# using lens correction (see the qrcodes_with_lens_corr.py script for higher performance).
import sensor, image, time
sensor.set_auto_gain(False) # must turn this off to prevent image washout...
img.lens_corr(1.8) # strength of 1.8 is good for the 2.8mm lens.
for code in img.find_qrcodes():
img.draw_rectangle(code.rect(), color = (255, 0, 0))
print(code)
### Implementation of POST and GET below#######
Re: How to implement POST and GET
Postby iabdalkader » Wed Feb 28, 2018 8:43 am
Just like you would in Python:
sock.send("GET / HTTP/1.0\r\n\r\n")
