OpenMV on ESP8266/ESP32
Paulner
Postby Paulner » Sat Feb 17, 2018 12:06 pm
I just saw this video and wondered about how to do so. Are there any wiring diagrams for an ESP and (e.g.) an OV7670 module in order to use the OpenMV IDE/Libary? What do I need to change in the source code?
Greetings
Paulner
Re: OpenMV on ESP8266/ESP32
Postby kwagyeman » Sat Feb 17, 2018 2:21 pm
Hi, that video just shows how OpenMV IDE can talk to any micropython board over a REPL terminal. There is no way as of right now to use OpenMV code with an ESP32.
Paulner
Postby Paulner » Sat Feb 17, 2018 3:17 pm
Thank you for the fast response. Is there another way to get a kind of a 'lite' version of OpenMV for just detection the size and ID of an apriltag? I don't have neither the space, the power to supply more modules nor do I need more functions in order to complete my project.
Greeting
Postby kwagyeman » Sat Feb 17, 2018 3:30 pm
The AprilTag code is in this file:
You can port it if you want...
https://github.com/openmv/openmv/blob/m ... apriltag.c
It depends on a ton of stuff in our code library though. Note that the EPS floating point performance is 7X worse than the OpenMV Cam. https://blog.classycode.com/esp32-float ... 9f6f567a69
So, expect a frame rate of about 1 FPS or less.
In the future, we plan to make our library portable. Mainly so we can get more community coding support.
Paulner
Postby Paulner » Mon Feb 19, 2018 2:21 pm
That sounds great! Do you already know when your system will be portable?
Postby kwagyeman » Mon Feb 19, 2018 2:31 pm
Um, for our upcoming STM32H7 launch we need to performance test on the Raspberry PI zero. So, maybe by May/June. Once we get the library in portable state it will run on any machine.
Paulner
Postby Paulner » Mon Feb 19, 2018 3:07 pm
Great news! I think until then I can wait :mrgreen:
