In the Cam H7 Plus description, it is mentioned “A removable camera module system allowing the OpenMV Cam H7 to interface with different sensors”
I would like to use OpenMV Cam H7 Plus to simultaneously test my application with different Cam H7 Plus having different sensors ( at least 5 sensors with different color absorption scheme ).
Please, I would like to check a few things:
1- how many sensors are supported by OpenMV Cam H7 Plus
2- If I want to use non-supported sensor, what I need to do (write my own driver?)
3- can OpenMV Cam H7 Plus outputs raw or uncompressed format (Uncompressed UYVY format)?
4- can I change the sensor setting (brightness, exposure, saturation…)
5- can I interface the Cam H7 Plus with a third-party CV library such as OpenCV?
Many thanks for the support!
