color detect in grayscale mode template
shadowfiredm
Postby shadowfiredm » Mon Jan 20, 2020 9:12 am
hi
im trying to detect the h,s,u letters and red and yellow colors in grayscale templeate mode for the rescue maze robot
but idk how to detect the red and yellow color in my code (my code is here :
import time, sensor, image, pyb
# Reset sensor
# Set sensor settings
sensor.set_contrast(1)
sensor.set_gainceiling(16)
# Max resolution for template matching with SEARCH_EX is QQVGA
sensor.set_framesize(sensor.QQQVGA)
# You can set windowing to reduce the search image.
#sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
# Load template.
# Template should be a small (eg. 32x32 pixels) grayscale image.
template = image.Image("/h.pgm")
templateh3 = image.Image("/h2.pgm")
templates = image.Image("/S.pgm")
templates2 = image.Image("/S2.pgm")
templates3 = image.Image("/S3.pgm")
templateh2 = image.Image("/h3.pgm")
# Run template matching
while (True):
    pyb.LED(1).off()
    pyb.LED(2).off()
    pyb.LED(3).off()
    # find_template(template, threshold, [roi, step, search])
    # ROI: The region of interest tuple (x, y, w, h).
    # Step: The loop step used (y+=step, x+=step) use a bigger step to make it faster.
    # Search is either image.SEARCH_EX for exhaustive search or image.SEARCH_DS for diamond search
    # Note1: ROI has to be smaller than the image and bigger than the template.
    # Note2: In diamond search, step and ROI are both ignored.
    r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
    r3 = img.find_template(templateh3, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
    s = img.find_template(templates, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
    s2 = img.find_template(templates2, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
    r2 = img.find_template(templates3, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
    s3 = img.find_template(templateh2, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
    if r:
        img.draw_rectangle(r)
        pyb.LED(1).on()
        print("HHHHHHHHHHHHHHHH!!!")
    elif r3:
        img.draw_rectangle(r3)
        pyb.LED(1).on()
    elif s:
        img.draw_rectangle(s)
        pyb.LED(2).on()
        print("SSSSSSSSSSSSSSSS!!!")
    elif s2:
        img.draw_rectangle(s2)
        pyb.LED(2).on()
    elif s3:
        img.draw_rectangle(s3)
        pyb.LED(2).on()
    elif r2:
        img.draw_rectangle(r2)
        pyb.LED(1).on()
can u help me plz or give me an idea my friends?
Re: color detect in grayscale mode template
Postby iabdalkader » Mon Jan 20, 2020 12:06 pm
The template matching only works on grayscale images, but you can switch the sensor pixel format to color and find the blobs after detecting the template.
