Determine square wire sizes
ali
Postby ali » Wed Jan 08, 2020 5:15 am
Hello
Our project is about capturing different squares and measuring the size or just one side.
Unfortunately I am not familiar with openmv and would need some help.
I would be very happy about ideas and help.
BR,
Ali
Re: Determine square wire sizes
Postby kwagyeman » Wed Jan 08, 2020 11:55 am
Have you seen the find rectangle command under examples -> feature detection? Also, try out find line segments under that sample example folder.
ali
Postby ali » Sat Jan 11, 2020 5:11 am
Hi there,
yes I tried it, but the problem is that it finds a lot of rectangles and not just our rectangle
Postby kwagyeman » Sat Jan 11, 2020 12:07 pm
Yes, you have to filter the output. That's entirely up to you in regular python code and by tuning the threshold argument of find_rect.
Our computer vision code just gives you the image->objects extraction. You then have to write a lot of code to throw away what you don't want. No way around this part.
Each rect is an object with methods to get access to it's x/y/w/h, etc. So, then you have to do something with that
