Sending image centroid coordinates to Arduino for further processing
srishtiganguly
Postby srishtiganguly » Sun Aug 25, 2019 10:06 pm
The project I am working on requires me to recognise a certain colour using the OpenMV camera, get the centroidal coordinates and send this data to an Arduino to further control 4 stepper motors, which will move a body to the location of the colour detected. Right now, I have managed to get the coordinates and send it to the Arduino as integers, but I don't think the process is working because the serial monitor is displaying a lot of garbage values along with the coordinates. (picture below)
The connections:
Arduino TX to OpenMV P4
Arduino RX to OpenMV P5
Gnd to Gnd
The OpenMV and arduino uno codes are as below:
OpenMV:
import sensor, image, time
from pyb import UART
uart = UART(3,9600, timeout_char = 1000)
        uart.write("%d\n"%blob.cx())
        uart.write("%d\n"%blob.cy())
        print("x=%d\n"%blob.cx())
        print("y=%d\n"%blob.cy())
Arduino uno:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(0, 1); // RX, TX
void getline(int *buffer, int max_len)
  uint8_t idx = 0;
  char c;
  do
    if(idx >= max_len) return;
    while (mySerial.available() == 0);
    c = mySerial.read();
    int coordinate = c - '0';
    buffer[idx++] = coordinate;
  while (c != '\n' && c != '\r');
  buffer[idx] = 0;
void setup() {
Serial.begin(9600);
mySerial.begin(9600);
void loop(){
  int buffer [63+1];
  int max_len = 63;
  getline(buffer, max_len);
  for(int i = 0; i < 64; i++)
    Serial.println(buffer[i]);
If I leave the coordinates as a string, then I get the correct output on the serial monitor, but I need to convert it to integer in order to control the stepper motors. Any help on this would be greatly appreciated!
Re: Sending image centroid coordinates to Arduino for further processing
Postby kwagyeman » Mon Aug 26, 2019 3:51 pm
Move the software serial to pins other than 0/1. Those are what the hardware serial monitor uses to send debug info to the PC. The Arduino only has 1 serial port. Software serial allows you to create another serial port on other pins.
