i am doing a project on face detection over wifi streaming.Faces are being detected in the ide but not in the browser over wifi. Please help me out in this.i am attaching my code .
# MJPEG Streaming AP.
# This example shows off how to do MJPEG streaming in AccessPoint mode.
# Chrome, Firefox and MJpegViewer App on Android have been tested.
# Connect to OPENMV_AP and use this URL: http://192.168.1.1:8080 to view the stream.
import sensor, image, time, network, usocket, sys
SSID ='OPENMV_AP' # Network SSID
KEY ='1234567890' # Network key (must be 10 chars)
HOST = '' # Use first available interface
PORT = 8080 # Arbitrary non-privileged port
# Reset sensor
# Set sensor settings
sensor.set_contrast(1)
sensor.set_brightness(1)
sensor.set_saturation(1)
sensor.set_gainceiling(16)
# Load Haar Cascade
print(face_cascade)
# Init wlan module in AP mode.
wlan = network.WINC(mode=network.WINC.MODE_AP)
wlan.start_ap(SSID, key=KEY, security=wlan.WEP, channel=2)
# You can block waiting for client to connect
#print(wlan.wait_for_sta(10000))
def start_streaming(s):
print ('Waiting for connections..')
client, addr = s.accept()
# set client socket timeout to 2s
client.settimeout(2.0)
print ('Connected to ' + addr[0] + ':' + str(addr[1]))
# Read request from client
data = client.recv(1024)
# Should parse client request here
Um, yeah, so, what are you trying to do and what exactly is wrong? You didn’t specify what actually isn’t working. You just posted some code with no indication what you are trying to communicate with.
Actually I am trying to view the detected faces over wifi. But, unsuccessful… I am not being able to send the faces through the socket… The video is being transmitted, but face detection is not… I have tried by changing the socket to a Tcp socket. But, I am not getting the idea that how to send the algorithm " for r in objects
Img.draw_rectangle(r)" over wifi… This is where I am stucked. Please help me out. I am trying for a long period and I have been through many videos and tutorials but unsuccessful…
Hi, you haven’t described what application is receiving your data. A socket has to connect to some device and send the data to it. If you want to do a WiFi based application you need to think about what will receive the data and clearly define a protocol for that reception.
Hello sir,
I have tried, but we can’t draw after compression… Rest of the code is working well, but I need to pack the draw_rectangle algorithm so that we can send it to wifi socket using client.send().
