I connect Wifi Sheild to OPEN MV and am making them move at present.
Using mpeg_streamer_ap.py.
An indication application is being made in VC# instead of OPEN MV IDE.
A character data could be received.
The file to receive image data isn’t found, so I think when you’d tell.
I can’t speak English, so a translation software is used, so it may be incomprehensible.
Thank you.
Hi, if you’re having trouble with our WiFi shield just use a second wifi based processor versus the OpenMV Cam. You can then hook the two devices up via serial comms. This may be easier for you.
Hi I understand there’s a language barrier but I can’t quite figure out what you want… maybe a picture with an arrow pointing to what you are talking about will help?
