imagedata directory
shu higashiyama
imagedata directory
Postby shu higashiyama » Tue Oct 16, 2018 3:59 am
I write for the first time.
I connect Wifi Sheild to OPEN MV and am making them move at present.
Using mpeg_streamer_ap.py.
An indication application is being made in VC# instead of OPEN MV IDE.
A character data could be received.
The file to receive image data isn't found, so I think when you'd tell.
I can't speak English, so a translation software is used, so it may be incomprehensible.
Thank you.
Re: imagedata directory
Postby kwagyeman » Tue Oct 16, 2018 10:12 am
Hi, if you're having trouble with our WiFi shield just use a second wifi based processor versus the OpenMV Cam. You can then hook the two devices up via serial comms. This may be easier for you.
shu higashiyama
Postby shu higashiyama » Tue Oct 16, 2018 11:36 pm
Thank you very much for your early answer.
It isn't transmitted successfully, so I'll question once again.
The picture taken in more than a camera is being indicated in OPEN MV IDE.
I'd like to make the program which moves in the same way by VC#.
So please tell me the stock location of the picture indicated in OPEN MV IDE.
Postby kwagyeman » Wed Oct 17, 2018 12:18 am
shu higashiyama
Postby shu higashiyama » Wed Oct 17, 2018 3:12 am
It may be a right response to a question, but 、、.
I couldn't look for a directory of a picture stock from the inside in designated SORCE file.
I'm sorry, but please tell me once again.
Postby kwagyeman » Wed Oct 17, 2018 3:36 am
Hi I understand there's a language barrier but I can't quite figure out what you want... maybe a picture with an arrow pointing to what you are talking about will help?
shu higashiyama
Postby shu higashiyama » Wed Oct 17, 2018 5:10 am
Excuse me, a question is changed.
" frame = sensor.snapshot ()", please, it was taken a picture of.
A picture is shown to the upper right in OPEN MV IDE.
Please tell me the name of this save image file.
Postby kwagyeman » Sun Oct 21, 2018 6:15 pm
The file isn't stored on disk. It's in the memory of the MCU. If you want to save it to disk please use see the Image Saving examples.
