OpenMV H7 on NUCLEO-H743ZI board
zoxno6
Postby zoxno6 » Thu Oct 04, 2018 4:01 pm
I have an NUCLEO-H743ZI with STM32H743 144 pins controller development board ( https://www.st.com/en/evaluation-tools/ ... 743zi.html ). I'm trying to install openmv4 firmware on it but without success. Will somebody help me?
Re: OpenMV H7 on NUCLEO-H743ZI board
Postby kwagyeman » Thu Oct 04, 2018 9:01 pm
We don't support that board. If you want to try to use our firmware on it you need to understand what you are doing.
zoxno6
Postby zoxno6 » Fri Oct 05, 2018 1:54 am
When you release OpenMV H7 schematic diagram?
Postby kwagyeman » Fri Oct 05, 2018 2:12 am
Yes, you once the Kickstarter ends. So, in 2 weeks.
zoxno6
Postby zoxno6 » Sat Oct 06, 2018 2:57 am
On which MCU is based OpenMV H7 board? Which is frequency of quartz crystal on H7 board?
Postby kwagyeman » Sat Oct 06, 2018 11:25 am
It's the STM32H7VIT6 with a 12mhz crystal.
victagayun
Postby victagayun » Sun Nov 04, 2018 9:29 pm
@zoxno6 Hello how are you uploading the firmware to this board?
@kwagyeman Do you support uploading your firmware to other opensource boards ie Nucleo? or even if we copy the SCH and make our own PCBs based on openMV HW design?
Postby kwagyeman » Mon Nov 05, 2018 12:01 am
We don't support the Nucleo. If you want to try to port our code to one you can. Its more work than it's worth however.
That said you can port the algorithms rather easy.
zoxno6
Postby zoxno6 » Mon Nov 05, 2018 5:24 pm
I upload successfully openmv4 firmware on Nucleo-H743ZI using STM32 ST-LINK utility, but PC ( OpenMV IDE) not see OPENMV - usb communication not work. I think it's because I do not have a camera sensor attached to Nucleo.
Postby kwagyeman » Tue Nov 06, 2018 10:41 am
Yeah, the firmware panics if it can't find a camera.
victagayun
Postby victagayun » Wed Nov 07, 2018 4:04 am
You may try this
https://sea.banggood.com/OV7725-Camera- ... rehouse=CN
zoxno6
Postby zoxno6 » Wed Nov 07, 2018 9:04 am
Dear victagayun , thank you for suggestion. For this module, I would have to make an adapter for the Nucleo Board. But the guys from OpenMV LLC gave us all the necessary files to create their hardware! I think I'll wait for the OpenMV H7 to go out for sale.
victagayun
Postby victagayun » Thu Nov 15, 2018 9:37 am
Hello I am a backer and ordered total 3pcs of H7.
But I see Mar'19 delivery time is quite very long.
So I plan also to buy NUCLEO-H743ZI board and similar camera.
The board might be big, but more IOs to play with.
Question is, when will the schematic be out?
Also, when is the support for Ili9341 be out too?
Postby kwagyeman » Thu Nov 15, 2018 11:52 am
I have to find some time to work on the Ili9341 driver.
As for the schematic, we were going to release it after the Kickstarter but have been asked by our partners to delay that until delivery least the system starts getting cloned immediately. Um, email me for an I/O pin map.
zoxno6
Postby zoxno6 » Sun Nov 25, 2018 8:56 am
What is manufacturer part number of connectors JP1,JP2 ,JP3 and X1?
Postby kwagyeman » Sun Nov 25, 2018 9:01 am
What board are you talking about?
zoxno6
Postby zoxno6 » Sun Nov 25, 2018 5:24 pm
Sorry, I think about H7 board.
zoxno6
Postby zoxno6 » Mon Nov 26, 2018 8:37 am
Also, what is manufacturer part number of connector X3 on H7 board - DF12-36-DS and DF12-36-DP on MT9V34 and OV7725 boards? What is height of this connectors?
Postby kwagyeman » Mon Nov 26, 2018 12:03 pm
It's the DF12(3.0)-36DP-0.5V(86) and DF12(3.0)-36DS-0.5V(86). Digikey has the info if you google it.
zoxno6
Postby zoxno6 » Tue Nov 27, 2018 3:26 am
Thank you kwagyeman. Can you write manufacturer part number of connectors JP1 and JP2 on H7 board?
Postby kwagyeman » Tue Nov 27, 2018 11:59 am
Hi, those are just standard molex 0.1 connectors. I don't have an exact part for them. Our CM just picks anything for use there.
Users browsing this forum: MSN [Bot] and 3 guests
