1. Fail to open any .py file
2. Firmware Version 2.8.0 [out of date - click here to upgrade]
Any suggestions ?
Thank you
Pei
Debugging starts
MimeDatabase: Error loading :/qt-project.org/qmime/freedesktop.org.xml
Cannot open :/qt-project.org/qmime/freedesktop.org.xml: No such file or directory
QFSFileEngine::open: No file name specified
Gtk-Message: 15:35:04.785: GtkDialog mapped without a transient parent. This is discouraged.
static Core::EditorManager::EditorFactoryList Core::Internal::EditorManagerPrivate::findFactories(Core::Id, const QString&) unable to determine mime type of /home/gv/Programs/Python/test2.py/. Falling back to text/plain
static Core::EditorManager::EditorFactoryList Core::Internal::EditorManagerPrivate::findFactories(Core::Id, const QString&): unable to find an editor factory for the file '/home/gv/Programs/Python/test2.py', editor Id ''.
// if (!fdoXmlFound) {
// // We could instead install the file as part of installing Qt?
#if (QT_VERSION >= QT_VERSION_CHECK(5, 11, 0))
const char freedesktopOrgXml[] = ":/qt-project.org/qmime/packages/freedesktop.org.xml";
#else
const char freedesktopOrgXml[] = ":/qt-project.org/qmime/freedesktop.org.xml";
#endif
allFiles.prepend(QLatin1String(freedesktopOrgXml));
3) Are you using the NEWEST qt-creator? Looks like you are still using qt-4.8 ?/opt/Qt/5.11.0/Src/qtbase/src/corelib/mimetypes/mime/packages/freedesktop.org.xml
g++ -c -pipe -O2 -std=gnu++11 -fvisibility=hidden -fvisibility-inlines-hidden -Wall -W -D_REENTRANT -fPIC -D'RELATIVE_PLUGIN_PATH="../lib/qtcreator/plugins"' -D'RELATIVE_LIBEXEC_PATH="../libexec/qtcreator"' -D'RELATIVE_DATA_PATH="../share/qtcreator"' -D'RELATIVE_DOC_PATH="../share/doc/qtcreator"' -DIDE_LIBRARY_BASENAME=\"lib\" -DQT_CREATOR -DQT_NO_CAST_TO_ASCII -DQT_RESTRICTED_CAST_FROM_ASCII -DQT_DISABLE_DEPRECATED_BEFORE=0x050600 -DQT_USE_FAST_OPERATOR_PLUS -DQT_USE_FAST_CONCATENATION -DUTILS_LIBRARY -DQTC_REL_TOOLS_PATH='"../libexec/qtcreator"' -DQT_NO_DEBUG -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CONCURRENT_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -I../../../src -I....../openmv-ide/qt-creator/src -I....../openmv-ide/qt-creator/src/libs -I....../openmv-ide/qt-creator/tools -I....../openmv-ide/qt-creator/src/plugins -I/opt/Qt/Current/gcc_64/include -I/opt/Qt/Current/gcc_64/include/QtWidgets -I/opt/Qt/Current/gcc_64/include/QtGui -I/opt/Qt/Current/gcc_64/include/QtConcurrent -I/opt/Qt/Current/gcc_64/include/QtQml -I/opt/Qt/Current/gcc_64/include/QtNetwork -I/opt/Qt/Current/gcc_64/include/QtCore -I.moc/release-shared -isystem /usr/include/libdrm -I.uic -I/opt/Qt/Current/gcc_64/mkspecs/linux-g++ -o .obj/release-shared/moc_theme.o .moc/release-shared/moc_theme.cpp
.moc/release-shared/moc_tips.cpp:57:6: error: ‘QTipLabel’ has not been declared
void QTipLabel::qt_static_metacall(QObject *_o, QMetaObject::Call _c, int _id, void **_a)
.moc/release-shared/moc_tips.cpp:65:38: error: ‘QTipLabel’ has not been declared
QT_INIT_METAOBJECT const QMetaObject QTipLabel::staticMetaObject = {
.moc/release-shared/moc_tips.cpp:71:20: error: ‘QTipLabel’ has not been declared
const QMetaObject *QTipLabel::metaObject() const
.moc/release-shared/moc_tips.cpp:71:44: error: non-member function ‘const QMetaObject* metaObject()’ cannot have cv-qualifier
.moc/release-shared/moc_tips.cpp: In function ‘const QMetaObject* metaObject()’:
.moc/release-shared/moc_tips.cpp:73:21: error: ‘QScopedPointer<QObjectData> QObject::d_ptr’ is protected within this context
return QObject::d_ptr->metaObject ? QObject::d_ptr->dynamicMetaObject() : &staticMetaObject;
In file included from /opt/Qt/Current/gcc_64/include/QtWidgets/qwidget.h:45:0,
from /opt/Qt/Current/gcc_64/include/QtWidgets/qframe.h:44,
from /opt/Qt/Current/gcc_64/include/QtWidgets/qlabel.h:44,
from /opt/Qt/Current/gcc_64/include/QtWidgets/QLabel:1,
from .moc/release-shared/../../../../../../qt-creator/src/libs/utils/tooltip/tips.h:30,
from .moc/release-shared/moc_tips.cpp:9:
/opt/Qt/Current/gcc_64/include/QtCore/qobject.h:433:33: note: declared protected here
QScopedPointer<QObjectData> d_ptr;
.moc/release-shared/moc_tips.cpp:73:21: error: invalid use of non-static data member ‘QObject::d_ptr’
/opt/Qt/Current/gcc_64/include/QtCore/qobject.h:433:33: note: declared here
.moc/release-shared/moc_tips.cpp:73:50: error: ‘QScopedPointer<QObjectData> QObject::d_ptr’ is protected within this context
.moc/release-shared/moc_tips.cpp:73:50: error: invalid use of non-static data member ‘QObject::d_ptr’
.moc/release-shared/moc_tips.cpp: At global scope:
.moc/release-shared/moc_tips.cpp:76:7: error: ‘QTipLabel’ has not been declared
void *QTipLabel::qt_metacast(const char *_clname)
.moc/release-shared/moc_tips.cpp: In function ‘void* qt_metacast(const char*)’:
.moc/release-shared/moc_tips.cpp:80:35: error: invalid use of ‘this’ in non-member function
return static_cast<void*>(this);
.moc/release-shared/moc_tips.cpp:81:39: error: cannot call member function ‘virtual void* QLabel::qt_metacast(const char*)’ without object
return QLabel::qt_metacast(_clname);
.moc/release-shared/moc_tips.cpp:84:5: error: ‘QTipLabel’ has not been declared
int QTipLabel::qt_metacall(QMetaObject::Call _c, int _id, void **_a)
.moc/release-shared/moc_tips.cpp: In function ‘int qt_metacall(QMetaObject::Call, int, void**)’:
.moc/release-shared/moc_tips.cpp:86:42: error: cannot call member function ‘virtual int QLabel::qt_metacall(QMetaObject::Call, int, void**)’ without object
_id = QLabel::qt_metacall(_c, _id, _a);
.moc/release-shared/moc_tips.cpp:123:6: error: ‘WidgetTip’ has not been declared
void WidgetTip::qt_static_metacall(QObject *_o, QMetaObject::Call _c, int _id, void **_a)
.moc/release-shared/moc_tips.cpp: In function ‘void qt_static_metacall(QObject*, QMetaObject::Call, int, void**)’:
.moc/release-shared/moc_tips.cpp:123:6: error: redefinition of ‘void qt_static_metacall(QObject*, QMetaObject::Call, int, void**)’
.moc/release-shared/moc_tips.cpp:57:6: note: ‘void qt_static_metacall(QObject*, QMetaObject::Call, int, void**)’ previously defined here
.moc/release-shared/moc_tips.cpp:131:38: error: ‘WidgetTip’ has not been declared
QT_INIT_METAOBJECT const QMetaObject WidgetTip::staticMetaObject = {
.moc/release-shared/moc_tips.cpp:131:49: error: redefinition of ‘const QMetaObject staticMetaObject’
.moc/release-shared/moc_tips.cpp:65:38: note: ‘const QMetaObject staticMetaObject’ previously defined here
.moc/release-shared/moc_tips.cpp:132:8: error: ‘QTipLabel’ has not been declared
{ &QTipLabel::staticMetaObject, qt_meta_stringdata_WidgetTip.data,
.moc/release-shared/moc_tips.cpp:137:20: error: ‘WidgetTip’ has not been declared
const QMetaObject *WidgetTip::metaObject() const
.moc/release-shared/moc_tips.cpp:137:44: error: non-member function ‘const QMetaObject* metaObject()’ cannot have cv-qualifier
.moc/release-shared/moc_tips.cpp:137:20: error: redefinition of ‘const QMetaObject* metaObject()’
.moc/release-shared/moc_tips.cpp:71:20: note: ‘const QMetaObject* metaObject()’ previously defined here
.moc/release-shared/moc_tips.cpp:139:21: error: ‘QScopedPointer<QObjectData> QObject::d_ptr’ is protected within this context
.moc/release-shared/moc_tips.cpp:139:21: error: invalid use of non-static data member ‘QObject::d_ptr’
.moc/release-shared/moc_tips.cpp:139:50: error: ‘QScopedPointer<QObjectData> QObject::d_ptr’ is protected within this context
.moc/release-shared/moc_tips.cpp:139:50: error: invalid use of non-static data member ‘QObject::d_ptr’
.moc/release-shared/moc_tips.cpp:142:7: error: ‘WidgetTip’ has not been declared
void *WidgetTip::qt_metacast(const char *_clname)
.moc/release-shared/moc_tips.cpp:142:7: error: redefinition of ‘void* qt_metacast(const char*)’
.moc/release-shared/moc_tips.cpp:76:7: note: ‘void* qt_metacast(const char*)’ previously defined here
.moc/release-shared/moc_tips.cpp:146:35: error: invalid use of ‘this’ in non-member function
.moc/release-shared/moc_tips.cpp:147:12: error: ‘QTipLabel’ has not been declared
return QTipLabel::qt_metacast(_clname);
.moc/release-shared/moc_tips.cpp:150:5: error: ‘WidgetTip’ has not been declared
int WidgetTip::qt_metacall(QMetaObject::Call _c, int _id, void **_a)
.moc/release-shared/moc_tips.cpp:150:5: error: redefinition of ‘int qt_metacall(QMetaObject::Call, int, void**)’
.moc/release-shared/moc_tips.cpp:84:5: note: ‘int qt_metacall(QMetaObject::Call, int, void**)’ previously defined here
.moc/release-shared/moc_tips.cpp:152:11: error: ‘QTipLabel’ has not been declared
_id = QTipLabel::qt_metacall(_c, _id, _a);
Makefile:19933: recipe for target '.obj/release-shared/moc_tips.o' failed
make[3]: *** [.obj/release-shared/moc_tips.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: Leaving directory '....../openmv-ide/build/src/libs/utils'
Makefile:110: recipe for target 'sub-utils-make_first' failed
make[2]: *** [sub-utils-make_first] Error 2
make[2]: *** Waiting for unfinished jobs....
rm -f libQtcSsh.so.4.2.82 libQtcSsh.so libQtcSsh.so.4 libQtcSsh.so.4.2
Users browsing this forum: Esteban Barba and 1 guest
