Upgraded to OMV IDE 1.9 and lost connection to camera module
danb22
Postby danb22 » Thu Jun 07, 2018 12:44 am
I just upgraded to the new IDE and can no longer connect to the camera module. It worked this morning with the previous version of the IDE (1.8?) but now it doesn't. Any advice would be much appreciated! Thanks - Dan
Re: Upgraded to OMV IDE 1.9 and lost connection to camera module
Postby kwagyeman » Thu Jun 07, 2018 2:25 am
What camera model? M4/M7?
danb22
Postby danb22 » Thu Jun 07, 2018 11:31 pm
M7 - and thank you for the help!
Postby kwagyeman » Fri Jun 08, 2018 12:15 am
Okay, can you give me any more info on the behavior if what the error is? What operating system are you using , when does the error occur, etc? If it's and M7 then you should be fine. This is well tested.
danb22
Postby danb22 » Thu Jun 14, 2018 1:15 pm
Problem corrected when i upgraded the OMV firmware. Not sure exactly what was causing this issue in the first place since the new IDE didn't even see the OMV module originally, but this time around it connected and said there was an available firmware update. I did that upgrade and my programs now run on the new IDE.
Postby kwagyeman » Fri Jun 15, 2018 12:17 pm
Great to hear. Thanks,
Users browsing this forum: Bing [Bot] and 4 guests
