CAM M7 availability after H7 release
frav
Postby frav » Mon May 07, 2018 2:55 pm
hello
I just finished the design of a vision system for industrial application. The system is designed to work as an auxiliary system for the machine that we are producing and selling worldwide.
Today I received the news of the next release of H7 version and I am quite concerned about the discontinuing of M7 support and availability on the market.
Do you have any information about that?
One more question: will H7 be compatible with M7 script and feature? I am using CAN interface to connect 30 CAM to a computer, will CAM bus be available on the H7 version?
Thanks, regards
robert_d1968
Re: CAM M7 availability after H7 release
Postby robert_d1968 » Mon May 07, 2018 8:58 pm
I'm with you on this one,
I have just started down this same path. I'm also wondering what will happen when the H7 gets released, does anybody have a time frame on this one?
Robert
Postby kwagyeman » Mon May 07, 2018 9:27 pm
Hi, the M7 and H7 are 100% compatible with each other. They are both built by ST and feature the same processor core. One is just fancier. The pheripals are all the same. With the H7 you'll just have a magic 2x speed boost. No work on your part will be required. Both versions also have the same amount of flash so the feature set will be exactly the same.
We plan to have M7 availability for the foreseeable future. We're not done with getting all sensors working with the H7 yet. Until then, we can't even start the Kickstarter, after the Kickstarter, we'll then go to manufacturing. This whole process is going to take a few months.
As for CAN. Yes, it has hardware support for this designed for automotive applications. However, neither me nor Ibrahim are experts in CAN. We'd love some community effort to help make the CAN pheripal more useful. Note that MicroPython already supplies some code to get the CAN interface working... However, I don't know what exactly to do with it.
If you're good with C we could make some money available for doing some documentation on the CAN interface and making it more obvious. There's already code to start with. So, only minimal effort is needed to figure out the right way to use it.
robert_d1968
Postby robert_d1968 » Wed May 09, 2018 12:31 am
Hello there,
This is taken right out of an example project From the STM32F arm.
/* Project name:
     CAN_1st (CAN Network demonstration with mikroE's CAN-1 module)
 * Copyright:
     (c) MikroElektronika, 2012.
 * Revision History:
     20110511(TL):
       - initial release;
 * Description:
      This code demonstrates how to use CAN library functions and procedures.
      It is used together with the CAN_2nd example (on second MCU), and it can
      be used to test the connection of MCU to the CAN network.
      This node initiates the communication with the 2nd node by sending some
      data to its address. The 2nd node responds by sending back the data incre-
      mented by 1. This (1st) node then does the same and sends incremented data
      back to 2nd node, etc.
      With minor adjustments, it should work with any other MCU that has a CAN module.
 * Test configuration:
     MCU:             STM32F107VC
                      http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00220364.pdf
     Dev.Board:       EasyMx PRO v7 for STM32(R) ARM(R)
                      http://www.mikroe.com/easymx-pro/stm32/
                      ac:CAN
     Oscillator:      HSE-PLL, 72.000MHz
     Ext. Modules:    None.
     SW:              mikroC PRO for ARM
'                     http://www.mikroe.com/mikroc/arm/
 * NOTES:
     - Turn on PORTE LEDs at SW10 and turn on CAN RX and TX switches at SW12.
unsigned long Can_Init_Flags;
unsigned char Can_Send_Flags, Can_Rcv_Flags; // can flags
unsigned char Rx_Data_Len;                                   // received data length in bytes
char RxTx_Data[8];                                           // can rx/tx data buffer
char Msg_Rcvd;                                               // reception flag
const long ID_1st = 12111, ID_2nd = 3;                       // node IDs
long Rx_ID;
void main() {
  GPIO_Digital_Output(&GPIOE_BASE, 0xFF00);
  GPIOE_ODR  = 0;
  Can_Init_Flags = 0;                                       //
  Can_Send_Flags = 0;                                       // clear flags
  Can_Rcv_Flags  = 0;                                       //
  Can_Send_Flags = _CAN_TX_XTD_FRAME &                      //     with CANWrite
                   _CAN_TX_NO_RTR_FRAME;
  Can_Init_Flags = _CAN_CONFIG_AUTOMATIC_RETRANSMISSION &              // form value to be used
                   _CAN_CONFIG_RX_FIFO_NOT_LOCKED_ON_OVERRUN &         // with CANInit
                   _CAN_CONFIG_TIME_TRIGGERED_MODE_DISABLED &
                   _CAN_CONFIG_TX_FIFO_PRIORITY_BY_IDINTIFIER &
                   _CAN_CONFIG_WAKE_UP;
  CAN1InitializeAdvanced(1,5,4,4,1,Can_Init_Flags, &_GPIO_MODULE_CAN1_PD01); // Initialize CAN module
  CAN1SetOperationMode(_CAN_OperatingMode_Initialization);                   // set CONFIGURATION mode
  CANSetFilterScale32(0, _CAN_FILTER_ENABLED & _CAN_FILTER_ID_MASK_MODE & _CAN_FILTER_XTD_MSG, ID_2nd, -1);
  CAN1SetOperationMode(_CAN_OperatingMode_Normal); // set NORMAL mode
  RxTx_Data[0] = 9;                                // set initial data to be sent
  CAN1Write(ID_1st, RxTx_Data, 1, Can_Send_Flags); // send initial message
  while(1) {  // endless loop
    Msg_Rcvd = CAN1Read(0, &Rx_ID , RxTx_Data , &Rx_Data_Len, &Can_Rcv_Flags);  // receive message
    if ((Rx_ID == ID_2nd) && Msg_Rcvd) {                                        // if message received check id
      GPIOE_ODR  = RxTx_Data[0] << 8;                                           // id correct, output data at PORTE
      RxTx_Data[0]++ ;                                                          // increment received data
      Delay_ms(10);
      CAN1Write(ID_1st, RxTx_Data, 1, Can_Send_Flags);                          // send incremented data back
