White Pixel Count
Tim H
White Pixel Count
Postby Tim H » Wed May 02, 2018 10:02 am
I have a Project at the moment while i want to count the amount of White Pixels in a Picture. I found nothing in the Forum and the Helps where i can see more Deatails of a Picture.
Is there any Solution to get a Integer number of how many Pixel are white in the Pixture and how many aren't?
Best Regards
Tim Hochstein
Re: White Pixel Count
Postby kwagyeman » Wed May 02, 2018 11:16 pm
Yes, use find_blobs(), set the color thresholds to pure white. Then sum up all the pixels() values from each blob returned:
count = sum(map(lambda x: x.pixels(), img.find_blobs([(100, 100)])))
For RGB565
count = sum(map(lambda x: x.pixels(), img.find_blobs([(255, 255)])))
For GRAYSCALE
Tim H
Postby Tim H » Thu May 24, 2018 3:24 am
Yeah perfect works fine. Thats a smart idea. With the find_blobs function.
Postby kwagyeman » Thu May 24, 2018 1:42 pm
Note find_blobs() expects a min blob size and area and will filter out white pixel outlier blobs. If you want all pixels then you need to tweak the parameters.
