serial terminal
pcls1026
serial terminal
Postby pcls1026 » Sat Feb 24, 2018 3:52 pm
When I PRINT too much data, the serial terminal does not accept all of it. Is there any cure ,other than writing a file to the SD card as I talked about on my previous post; "F.WRITE" .
Jim
Re: serial terminal
Postby kwagyeman » Sat Feb 24, 2018 4:33 pm
Hi, the serial terminal can only accept bytes at a fixed speed. After which our serial buffers fill up. Adding a wait on the printing of values will fix the issue. Um, what are you trying to do exactly?
pcls1026
Re: serial terminal
Postby pcls1026 » Sat Feb 24, 2018 5:44 pm
kwagyeman,
What do you mean by adding a wait. Is this a Python command?
I created a 3x24 2d list that I want to look at.
I attached code.
Jim
blksearch.py
(1.94 KiB) Downloaded 144 times
Re: serial terminal
Postby kwagyeman » Sat Feb 24, 2018 6:35 pm
The OpenMV Cam has a 512 byte buffer for characters that is polled every 2 ms. If you write data faster than this to the IDE then it can be lost. E.g. add pyb.delay(1) after printing three values. Anyway, your code works if you use an SD card. Please create a bug for the flash FS case on the github bug page.
pcls1026
Re: serial terminal
Postby pcls1026 » Tue Feb 27, 2018 3:34 pm
I'm sorry for the endless questions.
When I use pyb.delay(1) I get the error "NameError: name 'pyb' is not defined".
Code is attached.
copygrayvgatofile.py
(1.23 KiB) Downloaded 137 times
pcls1026
Re: serial terminal
Postby pcls1026 » Tue Feb 27, 2018 3:39 pm
HI,
I attached the wrong code in the previous reply.
Here is the correct code.
(1.23 KiB) Downloaded 134 times
Re: serial terminal
Postby kwagyeman » Tue Feb 27, 2018 4:11 pm
You have to import the pyb module.
pcls1026
Re: serial terminal
Postby pcls1026 » Tue Feb 27, 2018 6:08 pm
It works. Sorry for all the trouble.
Jim Sullivan
