UART data communication to arduino board question?
star
Postby star » Fri Feb 16, 2018 7:50 am
Hello there Openmv ,
I'm having problems trying to read color blob data coming into my Arduino board,
I'm trying to read and serial print same blob data from openmv
I don't know whats wrong, I'm new to openmv cam and I hope
bellow is the picture.I see 49,57 instead of 16 ...please I appreciate your help, as I have spent days trying to solve the problem ...thanks
Re: UART data communication to arduino board question?
Postby iabdalkader » Fri Feb 16, 2018 9:55 am
Hi, can you test with a serial terminal and see if you're getting the expected data ?
Postby kwagyeman » Fri Feb 16, 2018 11:51 am
Please post your OpenMV Cam code and Arduino code.
star
Postby star » Fri Feb 16, 2018 12:24 pm
OK ,Here's the openmv code
import sensor, image, time
from pyb import UART
uart = UART(3,9600, timeout_char = 1000)
    uart.write("%d"%blob.cx())
    print(blob.cx())
and here's the arduino code
int indata;
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
void setup() {
Serial.begin(9600);
mySerial.begin(9600);
void loop() {
indata = mySerial.read();
 Serial.print(indata);
 Serial.print("\n");
Postby kwagyeman » Sat Feb 17, 2018 1:35 am
Try this code:
        uart.write("%d\n"%blob.cx())
        print("%d\n"%blob.cx(), end='')
You had the wrong indentation in python. Also, you can't use "blob" outside of the loop. Whatever value you were using was a stale value.
Postby kwagyeman » Sat Feb 17, 2018 1:42 am
On the Arduino side:
https://www.google.com/search?q=arduino ... e&ie=UTF-8
You need a method to read a line of text. I.e. keep reading text until you see '/n'.
star
Postby star » Sat Feb 17, 2018 11:47 am
Thanks so much for your reply Sir,
now I'm 80% done, I have used the openmv code u sent and I have adjusted the Arduino code, the results are like this
I can receive the data from openmv but I need to reset before I can get a new data , that means I have to reset every time to get real-time data from openmv
here is the result ...Any help to resolve this i will really appreciate .thanks in advance
the arduino code
String str;
int ds = 4;
void setup() {
Serial.begin(9600);
void loop(){
   if (mySerial.available()){
    delay(100); // Wait for all data.
    while (mySerial.available()) {
        char d = mySerial.read();
        str.concat(d);
        char t[str.length()+1];
        str.toCharArray(t, (sizeof(t)));
        int intdata = atoi(t);
        Serial.print(intdata);
         Serial.print("\n");
         delay(100);
Postby kwagyeman » Sat Feb 17, 2018 2:19 pm
Try the attached. You might see some compile errors.
sketch_feb17a.zip
(449 Bytes) Downloaded 135 times
star
Postby star » Sun Feb 25, 2018 7:46 am
Thanks Sir , Everything worked well finally made a simple robot here https://www.youtube.com/watch?v=1enFgfF ... e=youtu.be
Postby kwagyeman » Sun Feb 25, 2018 11:48 am
Good job! Yo may wish to turn your PID gains down a bit.
