Why file.readall() removed from frimware 2.6!!
marcus007
Postby marcus007 » Mon Dec 11, 2017 11:16 pm
Today When I updated my OpenMV to Latest IDE with Latest Firmware I found that file.readall is not working at all , earlier it was working fine but now it raises an error
"TextIOWrapper object has no attribute 'readall' "
please do let me know what its substitute now
Re: Why file.readall() removed from frimware 2.6!!
Postby kwagyeman » Tue Dec 12, 2017 12:49 am
Mmm, that would be an MicroPython Hal change. Let's see the API:
It looks like you have everything here:
https://github.com/micropython/micropyt ... ile.c#L234
STATIC const mp_rom_map_elem_t rawfile_locals_dict_table[] = {
    { MP_ROM_QSTR(MP_QSTR_read), MP_ROM_PTR(&mp_stream_read_obj) },
    { MP_ROM_QSTR(MP_QSTR_readinto), MP_ROM_PTR(&mp_stream_readinto_obj) },
    { MP_ROM_QSTR(MP_QSTR_readline), MP_ROM_PTR(&mp_stream_unbuffered_readline_obj) },
    { MP_ROM_QSTR(MP_QSTR_readlines), MP_ROM_PTR(&mp_stream_unbuffered_readlines_obj) },
    { MP_ROM_QSTR(MP_QSTR_write), MP_ROM_PTR(&mp_stream_write_obj) },
    { MP_ROM_QSTR(MP_QSTR_flush), MP_ROM_PTR(&mp_stream_flush_obj) },
    { MP_ROM_QSTR(MP_QSTR_close), MP_ROM_PTR(&file_obj_close_obj) },
    { MP_ROM_QSTR(MP_QSTR_seek), MP_ROM_PTR(&mp_stream_seek_obj) },
    { MP_ROM_QSTR(MP_QSTR_tell), MP_ROM_PTR(&mp_stream_tell_obj) },
    { MP_ROM_QSTR(MP_QSTR___del__), MP_ROM_PTR(&file_obj_close_obj) },
    { MP_ROM_QSTR(MP_QSTR___enter__), MP_ROM_PTR(&mp_identity_obj) },
    { MP_ROM_QSTR(MP_QSTR___exit__), MP_ROM_PTR(&file_obj___exit___obj) },
And most of those methods are defined here:
https://github.com/micropython/micropyt ... y/stream.c
So, I'd use the readline() method to read one line in a loop. The readlines() method will return all lines in the file but that will cause you to likely run out of RAM given the file size.
Question, is the file a binary file? If so, then readAll() may still work on it. What mode did you open the file in?
