Hi is there any autofocus command for Openmv camera .Don’t want to do Manual adjustments
No the lenses have to be adjusted manually.
Motorized lens mount exists but are expensive. You can buy them yourself as an after market add-on.
After having such a motorized lens.
What have i to do with it in the code that it works??
You talked above in this thread over an autofocus lens with motor.
Is this modul focusing from alone or have i to code something that this works
You have to write your own code to do this. We don’t provide a routine for this.
