codes running related to powering up frequently
jisheng
Postby jisheng » Mon Oct 16, 2017 2:55 am
Dose anyone meet a problem that if you make openmv power on frequently, sometimes the program in the sd card cannot run? Is there any solution for this?
Re: codes running related to powering up frequently
Postby kwagyeman » Mon Oct 16, 2017 10:39 am
Can you post the code that causes this issue to happen?
jisheng
Re: kwagyeman
Postby jisheng » Mon Oct 16, 2017 9:12 pm
i just use the general code and i guess the it is not the codes causing this problem. I make a led light lit at the beginning of the codes to check. when it doesn't work, the led light doesn't work. it seems the codes don't run.
Postby kwagyeman » Tue Oct 17, 2017 12:39 pm
Can you post the code please?
Users browsing this forum: No registered users and 8 guests
