Fixed target point
DavidMactavish
Fixed target point
Postby DavidMactavish » Fri Sep 29, 2017 7:27 am
Hi everyone.
How to make Fixed target point or One point on the middle of the camera??? :!: :?: :!: :?:
please help me. :!: :!: :roll: :roll:
for example:
15488254-young-roe-deer-calf-being-targeted-by-a-hunter-with-the-crosshairs-of-the-scope-on-hiss-rifle.jpg
15488254-young-roe-deer-calf-being-targeted-by-a-hunter-with-the-crosshairs-of-the-scope-on-hiss-rifle.jpg (48.71 KiB) Viewed 1615 times
Re: Fixed target point
Postby kwagyeman » Fri Sep 29, 2017 11:43 am
Please put more effort into you forum requests. I don't know what you want. Please try to write about what you want, why you want it, etc. Try to write a paragraph or so.
Postby iabdalkader » Thu Oct 05, 2017 7:51 pm
Try:
img.draw_cross(img.width()//2, img.height()//2)
DavidMactavish
Postby DavidMactavish » Sun Oct 29, 2017 4:16 pm
Try:
hi men.tanks
Can this code be used in face detection???? :!: :?:
Postby kwagyeman » Sun Oct 29, 2017 5:14 pm
Yeah, just draw the target cross after detecting the face.
DavidMactavish
Postby DavidMactavish » Thu Nov 02, 2017 6:55 am
Try:
Hi, man. I want to have this square on the face detection. And I want this sign to be a positive sign.please help me. :!: :?: :idea:
Postby kwagyeman » Thu Nov 02, 2017 10:14 am
Just draw the cross after the face is detected on not. It's really that simple. Call the face detection method first. Then draw the cross.
DavidMactavish
Postby DavidMactavish » Thu Nov 02, 2017 5:12 pm
Please write the code for me.Because I do not know the writing code.
tanks men :!: :roll: :!:
Postby kwagyeman » Fri Nov 03, 2017 1:04 am
# Face Detection Example
# This example shows off the built-in face detection feature of the OpenMV Cam.
# Face detection works by using the Haar Cascade feature detector on an image. A
# Haar Cascade is a series of simple area contrasts checks. For the built-in
# frontalface detector there are 25 stages of checks with each stage having
# hundreds of checks a piece. Haar Cascades run fast because later stages are
# only evaluated if previous stages pass. Additionally, your OpenMV Cam uses
# a data structure called the integral image to quickly execute each area
# contrast check in constant time (the reason for feature detection being
# grayscale only is because of the space requirment for the integral image).
import sensor, time, image
# Reset sensor
# Sensor settings
sensor.set_contrast(1)
sensor.set_gainceiling(16)
# HQVGA and GRAYSCALE are the best for face tracking.
# Load Haar Cascade
# By default this will use all stages, lower satges is faster but less accurate.
print(face_cascade)
# FPS clock
while (True):
    # Capture snapshot
    # Find objects.
    objects = img.find_features(face_cascade, threshold=0.75, scale_factor=1.25)
    # Draw objects
    for r in objects:
        img.draw_rectangle(r)
    img.draw_cross(img.width()//2, img.height()//2, size = min(img.width()//5, img.height()//5))
    # Print FPS.
    # Note: Actual FPS is higher, streaming the FB makes it slower.
