Connect lcd to Face_Detection
DavidMactavish
Postby DavidMactavish » Tue Sep 26, 2017 7:53 pm
hi
Please help me Connect LCD to Face_Detection . :!: :?:
please Source code
:roll: :roll: :roll: :roll: :roll:
Re: Connect lcd to Face_Detection
Postby iabdalkader » Tue Sep 26, 2017 8:23 pm
Hi, you just need to add the following to the face detection example:
import lcd
lcd.init() # Initialize the lcd screen. (before loop)
And send images to LCD:
lcd.display(img) # display the image.
Full script:
import sensor, time, image, lcd
# Reset sensor
# Sensor settings
sensor.set_contrast(1)
sensor.set_gainceiling(16)
# HQVGA and GRAYSCALE are the best for face tracking.
sensor.set_framesize(sensor.HQVGA)
lcd.init()
# Load Haar Cascade
print(face_cascade)
# FPS clock
while (True):
    # Capture snapshot
    # Find objects.
    # Note: Lower scale factor scales-down the image more and detects smaller objects.
    # Higher threshold results in a higher detection rate, with more false positives.
    objects = img.find_features(face_cascade, threshold=0.75, scale_factor=1.25)
    # Draw objects
    for r in objects:
        img.draw_rectangle(r)
    lcd.display(img)
    # print FPS
DavidMactavish
Postby DavidMactavish » Tue Sep 26, 2017 8:51 pm
Thank you very much.
