lcd shield doesn't work
jisheng
Postby jisheng » Tue Apr 18, 2017 4:36 am
Re: Can the board works disconnected from IDE ?
Postby kwagyeman » Tue Oct 04, 2016 7:57 am
On my phone, so, short answer.
Click tools, and the then save to OpenMV cam. The IDE will then ask you if you want comments striped. Then go to tools and click reset OpenMV cam.
The board will now run the script you loaded onto it without the IDE
Today,I try the steps as introduced above, but something happens to my board. The LCD shield doesn't show the picture as the picture showed in the ide. Does someone know what happens? How can i fix this problem? Thanks
deshipu
Contact:
Re: lcd shield doesn't work
Postby deshipu » Tue Apr 18, 2017 6:49 am
You have to run the lcd example for this to work.
jisheng
Re:deshipu
Postby jisheng » Tue Apr 18, 2017 9:23 pm
I tried it just now, but it doesn't work still. :?
Postby iabdalkader » Tue Apr 18, 2017 9:49 pm
Can you send us an image of the shield connected ?
jisheng
Re:iabdalkader
Postby jisheng » Tue Apr 18, 2017 10:25 pm
Sure! I add it with the attachments. Can you see the picture?
Postby iabdalkader » Tue Apr 18, 2017 10:38 pm
No can't see any attachments, also please include the script you used for testing.
jisheng
Re: iabdalkader
Postby jisheng » Tue Apr 18, 2017 10:45 pm
# Hello World Example
sensor.skip_frames(10) # Wait for settings take effect.
how can I add the picture? I add it to the attachment and then submit, the picture cannot be upload to the post.
Postby iabdalkader » Tue Apr 18, 2017 10:50 pm
Click Attachments -> Add files then browse for the image, it will upload and then submit
Postby iabdalkader » Tue Apr 18, 2017 10:51 pm
You're not using the LCD at all in your script, unless there's a problem with the HW, this should work:
import sensor, image, lcd
sensor.set_pixformat(sensor.RGB565) # or sensor.GRAYSCALE
sensor.set_framesize(sensor.QQVGA2) # Special 128x160 framesize for LCD Shield.
lcd.init() # Initialize the lcd screen.
    lcd.display(sensor.snapshot()) # Take a picture and display the image.
jisheng
Postby jisheng » Tue Apr 18, 2017 11:05 pm
I tried the code you tell me.I think this time it works,but there are many stripes in the LCD shield. I cannot find the browse button in my web. Could you please tell me your email address, so that i can use the email to send you the picture. By the way, if I erase some thing by mistake, can it have an influence on the shield?
Postby iabdalkader » Tue Apr 18, 2017 11:27 pm
You can upload it somewhere like (http://imgur.com/) and just post the link.
jisheng
Postby jisheng » Wed Apr 19, 2017 9:32 pm
jisheng
Re:iabdalkader
Postby jisheng » Wed Apr 19, 2017 9:34 pm
hi, I post the picture. This is what the lcd shield like.
Postby iabdalkader » Wed Apr 19, 2017 9:51 pm
Hi, this shield is Not original, did you buy this from Taobao ? We've seen many clones lately on Taobao, they use low quality parts and 2 layers PCBs for the camera board, but also they change the design, which could cause issues. I can't be sure what's wrong with the shield, as we didn't make it.
jisheng
Re:iabdalkader
Postby jisheng » Wed Apr 19, 2017 10:00 pm
Yes, I bought it from taobao. So do you have a formal distributor in China?
Re: Re:iabdalkader
Postby iabdalkader » Thu Apr 20, 2017 5:56 pm
Yes, very soon we'll have a distributor in China, I'll let you know then.
jisheng
Postby jisheng » Thu Apr 20, 2017 9:01 pm
OK,thanks.
Re: Re:iabdalkader
Postby iabdalkader » Wed May 10, 2017 12:10 pm
Hey, we have a distributor in China now, you can order/pre-order directly from Seeed.
Postby kwagyeman » Wed Jun 21, 2017 11:16 am
We don't sell an LCD and keypad shield.
Users browsing this forum: Bing [Bot] and 11 guests
