Can someone tell me what’s going on, i can’t find a good solution. It is not clear what i have to do to fix it
My PI is in dutch i hope some one can understand it
De volgende pakketten hebben niet-voldane vereisten:
libpng-dev : Conflicteert met: libpng12-dev maar 1.2.54-6 zal geïnstalleerd worden
libpng12-dev : Conflicteert met: libpng-dev maar 1.6.36-6 zal geïnstalleerd worden
E: Kan problemen niet verhelpen, u houdt defecte pakketten vast.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: pyusb in /usr/local/lib/python2.7/dist-packages (1.0.2)
The following packages have unmet requirements:
libpng-dev : Conflicts with: libpng12-dev but 1.2.54-6 will be installed
libpng12-dev : Conflicts with: libpng-dev but1.6.36-6 will be installed
E: Can't fix problems, you are holding defective packages.
Okay, is this error preventing the IDE from launching? This looks like it would just be an error with the setup.sh script that tries to install dependencies. So, you might be able to ignore this.
that’s trouble number 2 it will not launch i have tried all of this code’s in the map where openmv is installed.
and then nothing happens even if i click on the file itself
