Servo
I have a question about the servos. As soon as I initialize the servos, they start putting out a signal and I don’t see how to disable them or put them in a known state. What I am trying to do is to activate the servos only when color red is detected. Here is the code. Any assistant will be much appreciated.
import sensor, image, time
from pyb import LED, Pin, Servo
#from move import forward, reverse, spin
red_led   = LED(1)
#rtwheel = Servo(1) # P7
#ltwheel = Servo(2)  # P8
#rtwheel.angle(45)  # move servo 1 to 45 degrees
#rtwheel.angle(0)    # move servo 2 to 0 degrees
ExtRedLEDOn = Pin('P0', Pin.OUT_PP, Pin.PULL_NONE)
ExtRedLEDOff = Pin('P0', Pin.OUT_PP, Pin.PULL_NONE)
red   = (  40,   60,   60,   90,   50,   70)
sensor.skip_frames(10)
sensor.set_whitebal(False)
red_led.off()
ExtRedLEDOn.low()
        blobs = img.find_blobs([red])
        if blobs:
                red_led.on()
                ExtRedLEDOn.high()
                for b in blobs:
                        img.draw_rectangle(b[0:4])
                        img.draw_cross(b[5], b[6])
                        #time.sleep(50)
                        # move servo1 and servo2 synchronously, taking 1500ms
                        rtwheel.angle(-60, 1500)
                        rtwheel.angle(30, 1500)
                red_led.off()
                ExtRedLEDOn.low()
Hmm, it looks like MP doesn’t come with the ability to turn them off. Try setting the pulse width to 0. E.g. When a color is detected drive the pulse width as normal or set it to zero when nothing is found. Servos only see a valid pulse width between 1000-2000us.
https://docs.micropython.org/en/latest/pyboard/library/pyb.Servo.html
