Count the white pixels on image
joao-pinto94
Postby joao-pinto94 » Fri Jan 17, 2020 3:10 pm
Theres any exemple of using greyscale YUV color space converted to monochrome and return the number of white points on image?
With the best Regards,
João
Re: Count the white pixels on image
Postby kwagyeman » Fri Jan 17, 2020 3:39 pm
Call the find_blobs(), pass color thresholds which look for white, then sum the pixels() value for each blob up. See the grayscale color tracking example to get started.
joao-pinto94
Postby joao-pinto94 » Sat Jan 18, 2020 7:20 am
Hi kwagyeman,
Thank you for the answer. Currenctly my code is:
thresholds = (245, 255)
sensor.skip_frames(time = 3000) #Just to understand if the sensor needs time before start
    for blob in img.find_blobs([thresholds], pixels_threshold=10, area_threshold=10, merge=True):
        x = blob.pixels()
        img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=90, color=127)
    sensor.flush()
    print(clock.fps(), x)
But some times i recive the error saying the 'x' isn't defined.
Could you please help me and understand if this is the better code for the solution?
With the best regards,
Joao
Postby kwagyeman » Sat Jan 18, 2020 3:04 pm
    blobs = img.find_blobs([thresholds], pixels_threshold=10, area_threshold=10, merge=True)
    for blob in blobs:
    white_pixels = sum(blob.pixels() for blob in blobs)
    print(clock.fps(), white_pixels)
You should read up on python lists and how to work with them. This is what makes python so powerful on the OpenMV Cam.
