I can not run OpenMV ide on a Raspberry Pi 4
kxekxe
Postby kxekxe » Fri Sep 20, 2019 6:22 pm
Hi!
I just downloaded the OpenMV IDE from the website for Raspberry Py.
I followed the procedure provided by the README.txt in the openmv folder but get this error message after I execute the openmvide.sh----
This application failed to start because it could not find or load the Qt platform plugin "xcb"
in "".
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, xcb.
Reinstalling the application may fix this problem.
Aborted
Operating system is Raspbian downloaded from the official site.
If someone has a solution to this problem, please share it.
Thank!
Re: I can not run OpenMV ide on a Raspberry Pi 4
Postby kwagyeman » Fri Sep 20, 2019 10:22 pm
Hi, you need to run the setup.sh file in the download zip. It installs the necessary modules for the IDE to run.
kxekxe
Postby kxekxe » Sat Sep 21, 2019 11:31 am
I did just that, but still I can’t run this application.
Postby kwagyeman » Sat Sep 21, 2019 11:44 am
Hi, I'll buy a Pi4. I last checked this on a 3. Note, we just support the official raspbian noobs image. I only test the IDE runs on a virgin OS. If you install anything that heavily changes how parts and libraries work I cannot easily support you.
kxekxe
Postby kxekxe » Sat Sep 21, 2019 1:18 pm
I installed it on virgin Raspbian downloaded from the official site raspberrypi.org.
I also tried installing it on a Raspberry pi 3 and got exactly the same result.
Maybe some kind of library version is not suitable?
ogagnon
Postby ogagnon » Thu Sep 26, 2019 7:09 pm
The issue is from a bad linked library.
This package have to be installed:
$ dpkg -S /usr/lib/arm-linux-gnueabihf/libts.so
libts-dev:armhf: /usr/lib/arm-linux-gnueabihf/libts.so
You can see here that the libqxcb.so plugin misses a link to a library:
$ ldd /home/pi/openmvide/lib/Qt/plugins/platforms/libqxcb.so | grep found
        libts-0.0.so.0 => not found
Creating a symbolic link to the correct library name fixes the problem:
$ ls -al /usr/lib/arm-linux-gnueabihf/libts.so
lrwxrwxrwx 1 root root 15 Jan 24  2019 /usr/lib/arm-linux-gnueabihf/libts.so -> libts.so.0.10.1
$ sudo ln -s /usr/lib/arm-linux-gnueabihf/libts.so /usr/lib/arm-linux-gnueabihf/libts-0.0.so.0
$ bin/openmvide.sh
Postby kwagyeman » Thu Sep 26, 2019 9:32 pm
Thanks for be fix. Mind sending a PR for the code to fix it here? https://github.com/openmv/openmv-ide/bl ... ke.py#L162
kxekxe
Postby kxekxe » Fri Sep 27, 2019 12:19 am
$ bin/openmvide.sh
Thank you so much!!!
But now i have this problem:
pi@raspberrypi:~/openmvide/bin $ ./openmvide.sh
Unable to query physical screen size, defaulting to 100 dpi.
To override, set QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT (in millimeters).
EGL Error : Could not create the egl surface: error = 0x3003
Postby kwagyeman » Fri Sep 27, 2019 12:21 am
Hi, is a monitor attached to your Pi?
ogagnon
Postby ogagnon » Sat Sep 28, 2019 9:29 pm
Here it is:
https://github.com/openmv/openmv-ide/pull/53
O.
ogagnon
Postby ogagnon » Sat Sep 28, 2019 9:36 pm
$ bin/openmvide.sh
Be sure that you sourced .bashrc after executing setup.sh or logged in again:
source ~/.bashrc
Explanations:
pi@raspberrypi:~/openmvide $ cat ~/.bashrc
# Force Qt Apps to use xcb
export QT_QPA_PLATFORM=xcb
pi@raspberrypi:~/openmvide $ unset QT_QPA_PLATFORM
pi@raspberrypi:~/openmvide $ bin/openmvide.sh
libEGL warning: DRI2: failed to authenticate
EGL Error : Could not create the egl surface: error = 0x300b
pi@raspberrypi:~/openmvide $ export QT_QPA_PLATFORM=xcb
kxekxe
Postby kxekxe » Sun Sep 29, 2019 7:09 pm
$ bin/openmvide.sh
source ~/.bashrc
Explanations:
Thank you so much again!
This was inside my bashrc:
cat ~/.bashrc
export LD_LIBRARY_PATH=xcb
I replaced the last line with "export QT_QPA_PLATFORM=xcb" and now it works!!!!
kxekxe
$ bin/openmvide.sh
source ~/.bashrc
Explanations:
cat ~/.bashrc
Postby kwagyeman » Sun Sep 29, 2019 9:12 pm
Nested quotes >_<
ARedGear
Postby ARedGear » Thu Oct 10, 2019 12:24 pm
I've followed the steps above, and I can get the IDE to run when I change my directory in the terminal, then run $bin/openmvide.sh.
Sadly though, when I try to just open the folder and double click the Openamvide.sh file it won't open..
Is their a way to make this work? or is their a way to create a desktop shortcut for this? I've tried a few ways but to no avail.
I'm doing some educational things with kids so I'd like them to just be able to click something and have it open.
Postby kwagyeman » Thu Oct 10, 2019 1:25 pm
Try restarting your device. The environment for the shell (the GUI) only gets reset on boot versus a terminal window is reset every time it opens. That script modified the environment so that has to be reloaded.
ARedGear
Postby ARedGear » Thu Oct 10, 2019 1:55 pm
Yeah same issue, if I open the folder directory in terminal, then type bin/openmvide.sh it opens the IDE, still a no go on just clicking openmvide.sh
When I try JUST clicking on the openmvide.sh I get the " Unable to query physical screen size, defaulting to 100 dpi.
EGL Error : Could not create the egl surface: error = 0x3003" Error... this seems very peculiar
Postby kwagyeman » Thu Oct 10, 2019 2:05 pm
Try this:
https://stackoverflow.com/questions/185 ... creen-size
I don't actually know what to do for this problem. I'm not in a place where I can debug this for your however right now for the next couple of days. Headed to a wedding. Id recommend googling for the solution. This issues isn't OpenMV specific. You're just running into general linux on raspberry pi issues.
ogagnon
Postby ogagnon » Sun Dec 08, 2019 2:37 pm
This is because the Main Menu links or by opening the file in the file explorer doesn't source .bashrc containing the line: export QT_QPA_PLATFORM=xcb
Also, the shebang at the top of the openmvide.sh file is pointing to /bin/sh while the export is for the bash shell.
The best way to resolve this issue is to change the first line of openmvide.sh to run bash (instead of dash) in interactive mode (sourcing .bashrc):
1c1
< #! /bin/sh
> #!/bin/bash -i
ogagnon
Postby ogagnon » Sun Dec 08, 2019 2:40 pm
Oh, and yes, I confirm it works. It's not only hypothetical ;-)
Postby kwagyeman » Sun Dec 08, 2019 11:31 pm
K, this will be fixed in the next release. I just fixed it in the branch.
ogagnon
Postby ogagnon » Mon Dec 09, 2019 7:56 pm
I just saw your change here: https://github.com/openmv/qt-creator/bl ... enmvide.sh
You should explicitly specify /bin/bash as the shell to be use. /bin/sh is a symlink in most distribution and in Debian-based ones, it's pointing to /bin/dash.
dash doesn't use ~/.bashrc.
Since you are using ~/.bashrc in here: https://github.com/openmv/openmv-ide/bl ... ke.py#L169, it won't work.
Most shells will use ~/.profile as the login source file. It's actually the file that sources ~/.bashrc but only when /bin/bash is used:
root@raspberrypi:~# cat .profile
# ~/.profile: executed by Bourne-compatible login shells.
if [ "$BASH" ]; then
  if [ -f ~/.bashrc ]; then
    . ~/.bashrc
  fi
fi
mesg n || true
root@raspberrypi:~# echo $BASH
/bin/bash
root@raspberrypi:~# /bin/sh
# echo $BASH
If you want to make sure the export QT_QPA_PLATFORM=xcb is always ran, you should append it to ~/.profile instead of ~/.bashrc.
But, since in your context, bash should be used, forcing #/bin/bash -i as the shebang of the openmvide.sh shall be preferred.
Explanation: https://askubuntu.com/questions/279285/ ... in-to-path
Postby kwagyeman » Tue Dec 10, 2019 12:25 am
Okay, updated that. Please send a PR for any more fixes you think would be good. Thanks for your help.
Users browsing this forum: MSN [Bot] and 5 guests
