OpenMV (Master) - Arduino Mega 2560 (slave) - SPI
Jivrik
Postby Jivrik » Wed Apr 03, 2019 9:08 pm
I would like to send chars from the arduino Mega(slave) to the openMV(Master) using the SPI connection.
I am trying to use the SPI.recv function in the openMV as shown in the code below
import sensor, image, time,pyb
from pyb import SPI
spi = SPI(2, SPI.MASTER, baudrate=115200, polarity=1, phase=0, crc=0x7)
pin = pyb.Pin("P3", pyb.Pin.IN, pull=pyb.Pin.PULL_UP)
buff = bytearray(4)
    print("HEY")
        # If we failed to sync up the first time we'll sync up the next time.
        #print("Sent Data!") # Only reached on no error.
        print("Ha")
        #print(buff)
        spi.recv(buff,timeout=5000)
        print(buff)
    except OSError as err:
        pass # Don't care about errors - so pass.
        # Note that there are 3 possible errors. A timeout error, a general purpose error, or
        # a busy error. The error codes are 116, 5, 16 respectively for "err.arg[0]".
    while(not pin.value()): pass
    print("END")
And here is the arduino code for testing it
#include <SPI.h>
//#include "pins_arduino.h"
#define SS 53
void setup ()
  Serial.begin (115200);
  digitalWrite(SS, HIGH);  // ensure SS stays high for now
  // Put SCK, MOSI, SS pins into output mode
  // also put SCK, MOSI into LOW state, and SS into HIGH state.
  // Then put SPI hardware into Master mode and turn SPI on
  SPI.begin ();
  // Slow down the master a bit
  SPI.setClockDivider(SPI_CLOCK_DIV8);
void loop (void)
  digitalWrite(SS, LOW);
  SPI.transfer('2');
  delay(1);
Please do you think I am missing something?
Thank you!
Re: OpenMV (Master) - Arduino Mega 2560 (slave) - SPI
Postby kwagyeman » Wed Apr 03, 2019 10:38 pm
Hi, your Arduino is not in slave mode there.
I highly recommend serial comms to connect the camera to an Arduino. It is much easier.
Users browsing this forum: No registered users and 23 guests
