maintaing same brightness throughout video
krishnakumar77777
Postby krishnakumar77777 » Thu Nov 29, 2018 4:46 am
How can i keep the brightness of video same throughout the video where the openmv cam will be moved in all x,y and z direction seperately in outdoor?
Re: maintaing same brightness throughout video
Postby iabdalkader » Thu Nov 29, 2018 11:08 am
Disable auto-functions ?
http://docs.openmv.io/search.html?q=set ... ea=default
krishnakumar77777
Postby krishnakumar77777 » Thu Nov 29, 2018 11:17 pm
By disabling all these,can i get the same amount of light even when the openmv moves?I explain my scenario. I want to detect lemon fruit in the plant in outdoor by making the scanning using movement of openmv cam on a slide. Can disabling helps me out?
Postby iabdalkader » Fri Nov 30, 2018 10:43 am
Yes, but you should let them run for a while to set some initial values, try this:
sensor.skip_frames(time=1000)
sensor.set_auto_gain(False)
sensor.set_auto_exposure(False)
krishnakumar77777
Postby krishnakumar77777 » Sat Dec 08, 2018 3:38 am
what will the polarizer filter do?
Postby iabdalkader » Sat Dec 08, 2018 7:38 pm
As I understand it, it attenuates a certain wavelength so you can use it in direct sunlight, it's like sun glasses. See the comparison photos in the product description:
https://openmv.io/collections/products/ ... ing-filter
I don't think that's what you need. It should be enough to disable the auto-functions like I mentioned.
jisheng
Postby jisheng » Mon Dec 10, 2018 9:56 pm
I think you are talking about making each frame have the same light even if the light outdoors changes. do i understand correctly?
krishnakumar77777
Postby krishnakumar77777 » Mon Dec 17, 2018 5:17 am
yes jisheng. you got it correctly. can you help me?
Postby kwagyeman » Tue Dec 18, 2018 11:16 am
Um, to do this you'd want to change the sensor exposure value based on the value returned by get_stats(). So, see the sensor control scripts and adjust the exposure up or down depending on if you're above or below some lightness threshold.
krishnakumar77777
Postby krishnakumar77777 » Fri Dec 21, 2018 10:36 am
hi,
lightness threshold means?what i want to use from get-statitics function? L or A or B? median or mean or standard deviation? help please
Postby kwagyeman » Fri Dec 21, 2018 11:06 am
Hi, use the median of the L channel and adjust the the automatic exposure accordingly.
krishnakumar77777
Postby krishnakumar77777 » Fri Dec 21, 2018 8:04 pm
I am also using the polarizing filter which i bought from you.
krishnakumar77777
Postby krishnakumar77777 » Mon Jan 07, 2019 10:53 pm
i need to detect white colored object within 3-5cm under sunlight using an color sensor. Which sensor best fit for this?
Postby kwagyeman » Mon Jan 07, 2019 11:59 pm
Hi, the OV7725?
Users browsing this forum: Bing [Bot] and 18 guests
