caffe instead of caffe2?
python2 instead of python3?
Anyway, catching up…
We’re basically using what ARM provided us. The implement work was mostly done by them. We’re just taking it from demo quality to usable.
Hi all , I’ve pre-ordered the H7 coming camera , and I’m really newby with OpenMV cams… waiting for the cam I’m checking the examples in the IDE software I already installed some days ago .
So I ordered this cam to make a basic Background subtraction work , but on ‘no-color’ objects ( small black objects moving ) . I’ve checked on the forum and I 'm not sure that the find blob method works on black objects ? did I missunderstood and will this work ? (it looks like it seems to look for a color range threshold no ? )
currently I’m using a working Rpi+ picam V2 solution, using OpenCV ( using background subtraction MOG2 type then FindContours method then ‘minEnclosingCircle’ method which gives me something like in the attached image . ) this allows me to find the biggest moving object ( white ‘blob’ ) and gives me his coordinates x,y + the Circle radius (which allows me to find an approximate detph as I know the average blob real world size … so = ‘z’ coordinate).
Do you think we can get such workflow/result with OpenMV H7 cam ?
Thanks by advance for any input over this .
and keep rocking guys , your product looks awesome , can’t wait to receive it .
Clem
Hi, I added all the features find_countours provides in OpenCV to our API. We have a minimum circle method now. If you’d like to the un-released firmware let me know.
As for doing what you want. First use frame differencing to create a difference image and then just threshold that image for non-block things (i.e. differences). find_blobs() will then give you the objects and you can filter in python to find the largest ones.
Hi Nyamekye ,
thanks for those great additions ! Do you have examples scripts of those already maybe ?
So this new minimumCircle method will return a radius value too ? ( to use for guessing the ‘Z detph’ )
yes please if you can share with me/us this new version that’ll be great
Ha ok for the frame differencing , I’ll check this more in details .
Thanks by advance
Clément
Example:
if blob.elongation() > 0.5:
img.draw_line(blob.major_axis_line(), color=(0,255,0))
img.draw_line(blob.minor_axis_line(), color=(0,0,255))
Do img.draw_circle(blob.enclosing_circle()) to draw the circle that encloses the blob. Note that the enclosing circle depends on the blob having a unique’ish shape. Otherwise the min area rect won’t be stable.
firmware.zip (923 KB)
oh I just see your reply Nyamekye , sorry !
thanks for the code !
